Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 01-06-2013, 07:09 PM
cwmuns's Avatar
cwmuns cwmuns is offline
Vehicle: 2005 Dodge Ram
Color: Blue/Gray
cwmuns is on a distinguished road
I have an 05 Ram and the place down the road from me has 10% for $3.17 and 100% pure for $3.51. Huge price difference. But if I need to use the pure, I'll switch. I love my truck and plan on having it for a long time.
Old 01-09-2013, 12:50 PM
Rep:1797
This is all great info guys
Old 01-09-2013, 01:37 PM
stroudtom's Avatar
stroudtom stroudtom is offline
Vehicle: 2011 ram 1500
Color: Gold
stroudtom is on a distinguished road
I have a 2011 RAM 5.7l ST single exhaust. I have a Trinty monitoring ST/LT kn and saw a increase in kn after filling with 10% cause I was travailing. Truck did a double kick down while climbing a incline in cruise. This had not happened any on the trip to my destination. Still on the MPG tune running 89 oct but I'll try the 93 next cause there's no benefit to low octane that I can tell.
Old 01-09-2013, 01:59 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
sorry if this is a dumb question but what is ST/LT kn?
Sean
Old 01-09-2013, 02:15 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
I don't even look at my MPG during the late fall to late spring seasons
damn winter blend gasoline sucks for mileage
There are other reasons vehicles get worse MPG in the cold months but from the fuel end it is primarily due to the increased butane in the mix. Butane is very cheap so it helps the price but it has far fewer BTU's when compared with gas. Refineries will use up to 10% if they can but butane vaporizes too easily so in the summer they can only use about 2%. In the winter the lower temps allow the refineries to add more butane. It has the positive effect of lowering prices a bit but it's bad for MPG.
Originally Posted by Chris b View Post
just a word to the wise. if your running 93gas with 10%Ethonal I would run the 91tune just to be on the safe side with less knocking and pinging
This doesn't make sense. First the octane rating of a fuel should be consistent no matter the blend. If you call it 93 then it's 93, ethanol or not. Sounds like something else is at issue or the 93 fuel you're buying isn't up to spec.
Actually, you are safer running ethanol than non-ethanol if you are worried about knocking and pinging because it has a slower burn wave. You won't make the same power, but you are less likely to have detonation issues with the advanced timing of the 93 octane tune if you run an ethanol blend.
Correct on the ethanol, but it's a blend. Fuel with a 93 octane rating and 10% ethanol doesn't resist knocking anymore than a 93 octane fuel with no ethanol. If it did it would have a higher octane rating.
Old 01-09-2013, 03:48 PM
OMALLEY808 OMALLEY808 is offline
Vehicle: 2009 Dodge Ram SLT
Color: stone white
Rep:64
OMALLEY808 will become famous soon enough
Short term/Long term knock
Short knock is only temporarily stored/adjusted by the pcm
Long term is stored/adjusted by the pcm over "long term"
Old 01-09-2013, 04:42 PM
snrusnak's Avatar
Rep:1385
Ok gotcha. Seems to me like it will knock to some extent no matter what(I've used several various tunes). I currently use a superchips 93 tune with 93 octane and it will retard timing as much as 6 degrees sometimes(heavy throttle/heavy load). I think going to 4.10 gears and lighter wheels/tires(less load) will help a lot.
Sean
Old 01-15-2013, 08:10 PM
cwmuns's Avatar
Color: Blue/Gray
I found a place not far from me that has no ethanol for just a few cents more on the gallon. I'll be filling up there now.
Old 01-16-2013, 09:40 AM
Rep:1797
The gas station I pump up at has 87 and 91
beside the 87 there is a sticker that 'contains up to 10% ethanol
beside the 91 there is nothing. does this mean that only the 87 octane contains the ethanol?
Old 01-16-2013, 09:44 AM
snrusnak's Avatar
Rep:1385
Maybe, you should ask.
So there's only 2 choices? That's odd. Every station here has 3+ choices. (usually 87 and 93, then they mix the two for 89 and 91
Sean
