Old 12-29-2012, 01:48 AM
osucowboys83 osucowboys83 is offline
Vehicle: 2013 Ram Sport
osucowboys83 is on a distinguished road
Does anyone have or know anyone looking to sell or just get rid of their old stock coils that will fit a 2013 Sport?
Old 12-29-2012, 10:41 AM
InDeepWaterBlue's Avatar
Rep:611
my friend Jeremy cut aftermarket coils to get a 3/5 static drop. Any lower and you have to c-notch the rear end. If you want to cut a coil, do your best to measure it out and don't use a torch to do it. I don't endorse cutting coils but if you're going to do it, do it as best you can
Old 12-29-2012, 11:37 AM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
That's way more than a 3/5...more like 5/7
This is a 3/5 static on an R/T. It's a 2/4 spring drop with 1/2 a coil off the front and a full coil off the rear....measure almost dead on 3/5 from stock height.
His looks great but does it have any suspension travel at all?
Old 12-29-2012, 12:10 PM
Rep:611
I know I'm not quite sure why I wrote 3/5 when it's more like a Belltech 4/6ish lol He has a little but it's a stiff ride for sure. compared to even your drop. I wouldn't mind dropping another inch around but I think I'm going to switch to air bags if I do. I can bolt them in stock locations without cutting anything and the ride would be smoother
Old 12-29-2012, 12:26 PM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
I keep thinking about dropping mine another inch but not with the rear link bars mounted like they are now. I have some ideas on those....the upper bar would be easy. Trim a couple of spots on it's mount and drill a new bolt hole and you could drop it a couple of inches. The lower bar will take some fab work and welding but doesn't look too hard to drop. Once those are moved a standard old school c-notch could be put in for some more travel. Notching the frame as it sits and the upper link bar will be the first point of contact with the frame....it already is if you have bump stops that are too short installed. I learned that the hard way.
Old 12-29-2012, 10:53 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
If chip foose cuts springs then we can too. My dads are cut to get a 2/4 drop on his 2012. I bought bell tech 2/4 w shocks for my 2012 express. If I put you in each truck you couldn't tell me which is cut, they ride and tow EXACTLY the same.
Now, to drop 1" front cut a half coil, to drop rear 2" cut one coil.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 12-30-2012, 10:07 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
I cut a full coil off my rear springs and it only dropped about an 1" at best. Once you go beyond that first coil the spacing between the coils increases greatly, so be very careful how much you cut off beyond that point. I still think starting out with some Mcgaughys 2" coils would be a better idea, jmo. Only $200 and are easier to cut since they are a progressive design (more "flat" coils).
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 01-01-2013, 10:19 AM
gmoneyRT's Avatar
gmoneyRT gmoneyRT is offline
Vehicle: 2011 Dodge Ram
Trim Level: RT
Rep:42
gmoneyRT is on a distinguished road
love the look of that blue rt, i think i saw a build thread where he c-nothed the rear a little. looks amazing tho!
Old 01-01-2013, 11:08 AM
Rep:611
Yup he C-Notched it, the thread is somewhere else on the internet lol
Old 01-01-2013, 04:03 PM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
Did he notch for the back of the upper link bar also or just the axle tube?
