Old 12-28-2012, 09:31 PM
HemiSter's Avatar
HemiSter HemiSter is offline
Vehicle: 2006 dodge ram hemi qc
Trim Level: sport qc
Color: silver
HemiSter is on a distinguished road
Default transmission swap yes or no
So i was gonna swap my transmission out next week bit i moved it today and it ran just fine but its still throwing these codes p0700 transmission control system , p0735 gear ratio error in 5th , p 0869 line pressure high , p 0734 gear ratio error in 4th , what the hell lol is it just a sensor or should i just go ahead and replace it thanx in advance guys
Old 12-28-2012, 09:43 PM
HemiSter's Avatar
Color: silver
Oh yea i forgot to inlcude my truck has 160k
Old 12-29-2012, 01:49 AM
HemiLonestar's Avatar
Rep:274
When it's in OD, does it feel like its popping out of gear or revving up real high? See if you can put fresh fluid/filter and if the speed sensor is bad. If not, you might be in the OD clutches are gone club.
"Big Red"
2006 Charger R/T
Old 01-02-2013, 09:27 AM
TransEngineer TransEngineer is online now
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
You should have a shop check the line pressure reading (using a scan tool). P0869 is rare, and it can mean the LP sensor is bad (or partially disconnected). You might first just make sure the LP sensor wiring connector is fully seated and latched. It is at the very rear end of the trans case, on the passenger side, just above the oil pan rail.
If it looks OK, then get it checked with a scan tool to see what it's reading. If it gives a false (high) reading, then the PCM will try to crank DOWN your line pressure (causing clutches to slip).
You may indeed have a burned OD clutch, but I would make sure the line pressure is OK first, before pulling the trans or tackling the gear ratio errors.
Old 01-02-2013, 07:38 PM
HemiSter's Avatar
Color: silver
Ok thanx guys ive been busy with the holidays i havent really had time but ill have it checked out and once again thanks
