Old 06-26-2013, 11:01 PM
Redhemi03 Redhemi03 is offline
Vehicle: 2003 hemi ram
Trim Level: Slt
Color: Flame red
Rep:26
Redhemi03 is on a distinguished road
Did you punch it while on the highway and it shift down to second prime? That's really the only way overdrive clutches get fried
2003 QC HEMI. 8.46@ 79.50, fastest NA 03 QC
Sidewinder cam, power wire,Tmr delete, edge 2800, hedman long tubes , Hedman ory pipe, 3" cutout, magnaflow 24", k&n CAI,Sharadon stage 3 VB, 4.56's, superchips 91
Old 06-26-2013, 11:03 PM
Trim Level: Slt
Color: Flame red
Rep:26
I could see a lot of ppl as well as myself testing how the custom tune pulls from highway cruising speed , which is exactly how I fried my od clutches
Old 06-26-2013, 11:19 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
I punch it everywhere should not of fried period did not get it to baby at certain speeds lol hey mustang sorry im doing 80 but i cant punch it so bye
Old 06-26-2013, 11:40 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
AMEN to that Brother!
I bag the hell out my 10' every day, and at the track on weekends,
...going on 4 years now without issue, Diablo canned 93 tune, no trans tuning
But with a new Ripp (*cough 500whp) waiting to install It's going to get a Built Trans from MGH!
From MGH:
"My built trans and tune is $2,500. You can still use your TC, but I would recommend an ATS triple clutch, Gabe and I both tune those and they are great. The reason that I recommend a triple clutch TC, is that I am working on a way to lock the TC in 2nd gear so that you get all the power down at the track.
I drive my truck like I stole it every day. hard launch from every stop light and I down shift manually and engine brake and I have not had a single trans problem.
Old 06-26-2013, 11:43 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
ya ill stick with the canned tune lol learned my lesson
Old 06-26-2013, 11:44 PM
Trim Level: Slt
Color: Flame red
Rep:26
Then you better save up for transfer swaps my friend, manually shift it out of overdrive before you punch it and you won't be in the situation you are in now, like I've told many ppl on here the 545rfe is not a bad trans other than the weak overdrive clutches. And if you think spending 3000 on a built trans, not gonna make much of a difference if y'all keep doing the same thing. I've seen multiple sharadon stage 3 transmissions be ran through from not manually shift out of OD. Sucks you dropped your trans, but I bet with that same tune and being a little more careful of not punching it out of OD and you would be a happy guy,
Old 06-26-2013, 11:46 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
so i can never punch it at high speeds what about without a tune
Old 06-26-2013, 11:53 PM
Rep:554
The stock OD clutch packs are garbage,
You cant even compare to what Mike is using to build his transmissions
"I also machine parts to add clutches for more friction area. Stock 2C has 2 clutches and 2 steels, I install 4 clutches and 4 steels. Stock Overdrive has 5 double sided clutches and 4 steels, I install 14 single sided clutches. Stock Underdrive has 4 double sided clutches and 4 steels, I install 12 single sided clutches."
MGH is kicking down any time he wants with a 500HP/500ftlbs TQ Twin Turbo 4G Hemi. 11 second Beast he's been baggin on for over a year now and has several other builds under his belt with the same results.
Shoot him a PM and you will come away impressed.
Trim Level: Slt
Color: Flame red
Rep:26
Just manually shift out of overdrive and you can punch it at any speed
Old 06-26-2013, 11:56 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Ive been running hemifever tune for over 6months and I bang on her everyday with NO problems.
SPONSORED BY
BULLY'S PERFORMANCE
