Old 12-16-2012, 10:03 PM
TVL's Avatar
TVL TVL is offline
Vehicle: 2015 Ram 2500 Crew
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Default Amp Research Power Step
Just installed my new Amp Research Powerstep! It took quite a while to do, but it is finally done... not without some angst and gnashing of teeth.
I have to give a shout out to Auto Anything! They were great. Got a nice discount from them and fast shipping. I have nothing but good to say about them.
My words about Amp Research (the manufacturer of the product) are mixed.
I have no complaints about the quality of the product. Very well made. Almost all the parts and components seem to be top quality.
I have two issues with the components. In my opinion, the templates should be rigid plastic or metal, not flimsy cardboard. The holes you have to drill through the pinch plate under the doors, need to be exact. The templates provided are not adequate. The other issue is the connection to the LED lights. In my opinion, butt connectors are named that because they suck ass. Very sloppy way of connecting wires...especially under a vehicle where water, salt and road grime is present. I know the instructions say to cover them with tape and plastic conduit, but using this type of connector is very unsecure (in my opinion). The kit has great connectors for tapping into the fusebox wires, I'm sure there is a similar connector available for this type of application, BETTER than a butt connector. I soldered the wires, then heat shrink tubing, tape and Plastic conduit.
The biggest issue I had was with missing parts. When the package arrived on Thursday, I immediately went through the parts list and matched it up with everything in the box. What I didn't check was that one of the pre-assembled control arms had two parts missing. By the time I discovered it, I was in the middle of the installation and it was Saturday afternoon. Of course when I called Amp Research, they were closed. Not that it mattered....they wouldn't have shipped the parts until Monday anyway. It was probably good that there were closed. My attitude at that point was not exactly Christian. Nothing more irritating than missing parts that you can't go buy anywhere locally after spending $1000 on a product.
Fortunately for me, I have a shop at work where I could go and make the part. What was missing was a 1/4 X 20 hex bolt(which I got at Home Depot) and a wedge shaped aluminum piece with a threaded hole (for the 1/4 X 20 hex bolt). I milled and cut the part from stock brass (pictured below).
Overall, I love the product on my truck! I like the clean look of no running boards, so this product was ideal for me. It works very well!
If you are considering buying this product, you need to be experienced and quite handy when it comes to modding your vehicle. I could handle the challenges....but at my age, after crawling around under my truck for several hours, I felt like I fell out of a tall tree and hit every branch on the way down!
Even after my complaints and issues, I still give this product 4.7 out of 5
2015 Ram 2500 6.4L Hemi, 4:10 gear ratio, 5" Rough Country Lift, 20" MotoMetal 962 Wheels with 0 offset, Nitto Trail Grappler 37 X 12.50 Tires, Bakflip G2 Box Cover, LineX Spray-on Bedliner, Amp Research Power step
Old 12-16-2012, 11:18 PM
Crash Crash is offline
Vehicle: 2016 Laramie Longhorn Limited
Trim Level: Laramie limited
Color: Black crystal pearl
Rep:404
Sorry to hear you had problems with missing parts, I would have been POed too. And I agree about the Butt conns I did the same as you,soldered shrink tube. I've had mine a couple of year now and still love them. Hope you do too. Your ride looks good!
Old 12-17-2012, 10:32 PM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
They look great! How long was the install?
Old 12-17-2012, 10:41 PM
TVL's Avatar
TVL TVL is offline
Rep:147
Total time was about 10 hours between 2 days. Keep in mind that I had to make a run to Home Depot for the missing bolt and drive down to work and spend an hour milling and drilling the missing wedge nut, About 30 minutes (total) swearing, 15 minutes or so wondering why I do this to myself, and some breaks for bread and water.
There definitely was a learning curve involved. The first side took much more time including the parts run and fabrication. The other side went quicker when I knew what to expect. The electrical was much easier!
Old 12-18-2012, 12:01 AM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
looks good congrats on your new steps the amp are in my opinion the best power steps out there.
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 01-02-2013, 01:12 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Your mods are becoming very similar to mine.....LOL
Nice setup
Old 01-02-2013, 03:45 AM
TVL's Avatar
TVL TVL is offline
Rep:147
Nice setup
Thanks! Great minds think alike!
One difference will be our headlights. They will be similar. I just ordered a set from pro tuning labs. They will be projectors and HID with halos and LEDS.
I also ordered from them a LED light bar for stop, signal, tail and reverse lighting.
After each thing I do, I always think I'm done. Then I find something else that I NEED! (like 4.56 gears!)
Old 01-02-2013, 10:09 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
i had the same problem... missing parts... and they don't like the snowy slushy conditions...
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 01-02-2013, 10:55 AM
Revel Performance
Rep:1804
Which headlights? They have so many to choose from.....LOL
As for the gears, you will greatly see an improvement in performance.
Not sure if you feel it sluggish, but if so, ALL that will go away
Old 01-02-2013, 07:29 PM
TVL's Avatar
TVL TVL is offline
Rep:147
Here are the headlights I ordered. They are the HID-PRO-YD-DR09-HL-BK
