Old 01-02-2013, 04:07 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
To answer your question. If you are keeping the same wheels and want the wheels/tires to fit the same (stick out) as they do without the flares then you will need to measure how much the flares stick out from the fender then add a spacer that's the same width. If your flares are 2" then you will need 2" spacers, 2.5" flares = 2.5" spacer and so on.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
Old 01-02-2013, 06:01 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
i don't think a 2.5'' spacer is a good idea.... an offset wheel would be the best bet
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 01-02-2013, 10:01 AM
Vehicle: 2012 Dodge Ram CC 4X4
Color: PX8 Black
Rep:1772
To add to this and correctly clear this up, it is wheel adapters you seek vs spacers.
If you go this route, make sure it is hub centric and if possible wheel centric, but this isn't necessary as you can always put wheel hub rings on.
I still would not go this route. Too much strain on your stock components and also the possibility of rubbing which will require some trimming
What he ^^ said
2014 Ram Hemi Tuning now available from Diablo Sport get yours today!
