Old 12-29-2012, 09:24 PM
WhiteRamSport13 WhiteRamSport13 is offline
Vehicle: 2013 Dodge ram
WhiteRamSport13 is on a distinguished road
Default Where to buy mopar mud flaps?
Looking to buy some mopar mud flaps for front and rear on my 2013 ram sport 1500. Anyone know where I can get the best deal?i think they will look best on my white ram. Or any other ideas?
Old 12-30-2012, 02:25 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Where in BC are you? You can have the rear ones I took off my truck the day I bought it. They are the dealer installed ones. As long as you dont mind it saying Langley Chrysler on em. I'm in Delta.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 01-01-2013, 11:00 PM
Thanks man but I'm looking for specific ones.
Old 01-05-2013, 11:26 PM
Chugbug's Avatar
Chugbug Chugbug is offline
Vehicle: 2012 Ram
Color: While
Rep:29
Chugbug is on a distinguished road
Default OEM mudflaps
Sorry, dual post see post below
Last edited by Chugbug; 01-05-2013 at 11:50 PM. Reason: Sorry, please see post below
Old 01-05-2013, 11:44 PM
Chugbug's Avatar
Vehicle: 2012 Ram
Color: While
Rep:29
I wouldn't go with OEM, main reason even though they are the mopar OEM, they have to drill 1 extra hole per flap. There are several aftermarket flaps out there that require no drilling to install. I had the OEM's installed and ended up going back to the dealership then to another dealership 3 times becasue they could not get the fronts to install tight and they would vibrate / flap when driving. This ended causing damage to the paint and they had to repaint. I had them remove and reimburse me which they did but the idiot that installed the flaps over torqued when drilling the holes left the holes raised with sharp edges so they had to grind the area down tac the holes and repaint. Had I known they had to drill holes in my new truck I would never had them installed....I'd look else where, Good luck, let us know what you ended up doing.
Old 01-06-2013, 09:59 AM
RAM SPORT CREW's Avatar
RAM SPORT CREW RAM SPORT CREW is offline
Vehicle: 2012 Ram Sport Crew
Rep:110
RAM SPORT CREW will become famous soon enoughRAM SPORT CREW will become famous soon enough
I put weather tech on my 12 sport and there is no drilling required. There is an option to secure the fronts with an additional bolt and nut (all stainless hardware) but its only drilled through the plastic inner fender, so no worry about rust. They fit perfect and I adjusted them out a smidge so they don't rub on the side of the body and chafe the paint causing rust in the future. Very nice product same as their floor mats
Old 01-06-2013, 10:04 AM
sebber sebber is offline
Vehicle: 2014 Ram 3500
Rep:14
sebber is on a distinguished road
I concur with Weather Techs. I tried the Mopars on and preferred the look and feel of the weather techs!
2012: 2012 Ram 1500/ RV:2012 Palomino S17
2013: 2012 Ram 2500/ RV:2013 Denali BH311
2014: 2014 Ram 3500/ RV:2014 Sabre QSIK35
A truck a year keeps the doctor away!
Old 01-06-2013, 01:47 PM
jb502 jb502 is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT, Bighorn
Rep:14
jb502 is on a distinguished road
Got some from my dealership yesterday for 45 dollars each set. 90 total. I put them on today, pretty easy. You do have to drill 1 hole for each flap. I drilled the front ones, but not the back because I would have had to take my wheel off to do it. Seems sturdy enough without that screw. I may take the wheel off in the summer and put it in.
Old 01-06-2013, 02:56 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Are these the ones you got?
Hope not, these will screw up your paint, they flap in the wind at highway speeds and sand down your paint on the sides. Weathertech are by far some of the best no screw mud flaps
Old 01-06-2013, 07:11 PM
Rep:14
Those are the ones I got.
