Old 12-30-2012, 11:38 AM
chris.brown chris.brown is offline
Vehicle: 1996 dodge ram 2500 4x4
Color: green
chris.brown is on a distinguished road
Default no spark to coil , asd relay keeps clicling out.
My 96 was running fine i don't drive it a lot at least once a month .
when it stared off it it would just turn over would not start, then i lost all the lights on the dash, check engine, brake, then then the radio stopped coming on.
when i first turn on the key i have power to the asd relay but when you turn it over it clicks out and stops making the connection.
Any ideas on what direction i should go in to correct this and get her going again?
Old 12-30-2012, 01:50 PM
06PowerWagon's Avatar
06PowerWagon 06PowerWagon is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Power Wagon
Rep:26
06PowerWagon is on a distinguished road
Battery might be running out and run the code reader on her.
Smile even if its a little creepy
Old 12-30-2012, 08:59 PM
Color: green
I tried a new battery . At first the code reader said no codes then err1 started flashing on the screen.
Old 12-31-2012, 07:09 PM
Rep:26
put the code reader on and try cranking it
Old 01-06-2013, 07:11 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Could be a bad ignition switch. They do not last.
asd automatic shut down, no pwer to coil
