Old 12-30-2012, 11:51 AM
poseidon7902 poseidon7902 is offline
Vehicle: 2013 Ram Sport Quad Cab
poseidon7902 is on a distinguished road
Default Bluetooth problems
Anyone else using a Samsung S3 to stream media to the system in their Rams? I have the nav unit with the larger screen (8.4AN/RA4) and have a really bad problem with streaming media via bluetooth. This only happens when streaming media. If I'm on the phone or listening to radio/satellite radio it never happens. So here's the problem.
It drops connection constantly. Some days I can go an hour or even 2 without a drop. others it drops the connection less than every 5 minutes. I contacted Verizon and they sent me a new phone under warranty. I wanted to eliminate that aspect of the equation right away knowing that's the first thing Chrysler would blame. Nope. Problem persists. Took it into the dealership and they said. Sorry, but we don't know what's causing it.
So anyone else using the S3 to stream media (Google Music, Pandora, Last.fm etc...) with or without problems?
Old 12-30-2012, 01:09 PM
luckymckay21 luckymckay21 is offline
Vehicle: 2013 Ram Bighorn 4x4
Rep:12
luckymckay21 is on a distinguished road
Using my Google nexus phone, it use to drop the signal every 5 minutes or so. By the third day at home, my truck seems to have stopped dropping my signal. Not sure why, but I haven't had to reconnect my audio Bluetooth in a while. Keeping fingers crossed it stays that way.
Old 12-30-2012, 02:58 PM
It drops and says "Connect Device" on the screen, but if I wait anywhere from 10 seconds to a couple minutes, it'll just reconnect on its own. It's very frustrating especially considering I don't have a CD player in the truck.
Old 12-30-2012, 11:21 PM
Cookie Monster Cookie Monster is offline
Vehicle: 13 1500 Laramie Crew 6'4
Trim Level: Laramie 8Speed 4x4
Color: True Pearl Blue
Rep:71
Cookie Monster will become famous soon enough
I know you said you replaced the Phone but just check make sure the phone is running the latest OS update. I had some GS3 friends have issues with BT drop outs streaming audio and after the last update (released in early Dec) their issue went away. Just wondering if the replacment phone they sent you was updated or not as the updates release wasn't that long ago.
Old 12-30-2012, 11:35 PM
Yep. it's at 4.1 jellybean. I have no problem using the device in my Ford, so it's something to do with the Ram specifically. Oddly enough, I rented a Town and Country about 2 months ago and had no problem with it streaming either now that I think about it.
Old 12-30-2012, 11:46 PM
Rep:2705
You may want to check out the wk jeep site, they have had these new radios for a year or more
Rams just started using them in October
you should have received a manual on the radio, nav, uconnect, when you purchased your Ram
Rep:71
I'd go back to the dealer and try streaming from your phone to another RAM with the same radio and see how that works. if its ok then I'd say that your RAM's radio has an issue. then get them to replace the radio under warranty.
Old 12-31-2012, 10:41 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
The T&C had a different radio in it, correct? Probably an RES, REQ RBZ or RHB. The S III works great with these systems.
Just a FYI, Uconnect is not Uconnect in all vehicles. There are 3 different suppliers because there are 3 different radio suppliers and Uconnect is Engineered differently by them.
So comparing the T&C to your RAM would only tell you that the phone worked better with 1 supplier than the other.
Old 12-31-2012, 12:36 PM
Good point. It definitely was a different radio. I'm also going to talk with the dealership to see if another Ram drops the connection as well.
Old 12-31-2012, 02:42 PM
kro138's Avatar
kro138 kro138 is offline
Vehicle: 2013 RAM 1500 SLT
Rep:12
kro138 is on a distinguished road
I have the 8.4N/RA3 in my 2013 and have also experienced the bluetooth "skipping" like a CD. I'm using an iPhone 4 and haven't had this problem with other devices. Like your problem it sometimes doesn't happen and other times every min or so. I usually leave my phone in the cup holder, but sometimes leave it in my left pocket. I have noticed no difference between the two.
Croydon
