Old 07-11-2013, 07:30 PM
Driver72 Driver72 is offline
Vehicle: 2014 Laramie CC 4x4 8spd 3.92
Color: White w/ Blk interior
Rep:69
Driver72 will become famous soon enough
Thanks guys, so it's safe to say the stock 20" wheels on the Ram Hemi's are
33-35 lbs each and the tires (according to Tirerack) are 40-42 lbs each.
Thanks
2015 Dodge Challenger Hellcat - 8spd
2014 Ram 1500 Laramie CC 4x4 with LSD and 3.92's -GONE-
2013 Ram 1500 Laramie CC 4x4 with LSD and 3.55's -GONE-
Old 07-11-2013, 08:30 PM
Thanks
So 73-77lbs.
Which is pretty accurate.
Don't think I've ever seen a set of them weigh more than 74lbs.
But regardless, it's close.
Old 07-12-2013, 07:28 AM
Rep:69
If the wheels really are about 33-35 lbs each, that's actually not too bad for an OEM wheel of this size.
I was looking at some aftermarket wheels in the same size on Tirerack and with the exception of just a handful, most are 33+ lbs.
I usually look for aftermarket wheels that will save some rotational mass and look sweet at the same time, and that's usually not too hard with OEM wheels usually being quite heavy, but in this case, it may be a challenge if I decided to put aftermarket wheels on the new truck.
Old 07-12-2013, 11:18 AM
You are correct!
Many aftermarket 20" weigh in the neighborhood of 36-45lbs depending on width.
Rockstars for example in 20x10 is 45lbs
Moto Metal 962 in 20x9 is 36lbs
But most if not all mainstream 20" aftermarket wheels do weigh more than our stock
Usually it is the other way around
Old 07-12-2013, 05:11 PM
Rep:69
Yeah and that's a bit of a bummer for me.
One of the joys I get out of getting a new vehicle (which is pretty often for me LOL) is putting aftermarket wheels on it, not only for looks but for function.
It feels good to be able to buy aftermarket wheels that are (usually for me) 5-10 lbs lighter EACH. Reducing rotational mass, which of course, improves acceleration, braking, steering response and improves fuel economy. It's a royal flush win.
But in the Ram's case, it seems it will be hard to drop more than 2 lbs each wheel and that's only if I can find the (probably very few) wheels that are under 33 lbs AND look better than the stock Laramie 20" wheels. May be a tough one.
On top of that, often if the OEM tires aren't the best rated or are quite heavy, I'll order new tires as well, ones that are higher rated AND lower weight. But again, Ram did their homework, I've noticed (I think) only 1 tire on Tirerack that's lighter than the stock truck tires (and only by 1-2 lbs each).
So the joy and individuality of aftermarket wheels/tires for me may not happen on this truck. And I really don't have the need or desire to go with larger wheels, or tires for that matter. Maybe my mind will change if I see the right set up on another Ram truck that makes me drool.
Thanks
Old 07-12-2013, 06:19 PM
If you're going based off weight, them yes, you'll be hard pressed unless you spent $$ on forged wheels.
But the Hemi has plenty of power to move wheels even if they are 5-10lba heavier.
Old 11-08-2013, 10:51 AM
Rep:69
On the subject of our stock wheels again, they are 20 x 9 inch correct?
And who has the bolt pattern and backspacing of our stock wheels handy?
Thanks
Old 11-08-2013, 11:46 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Here you go.
2004 Truck Wheels, Lug Nuts & Wheel Valves
http://www.dodge.com/bodybuilder/200...tro/twlnwv.pdf
2006 Truck Wheels, Lug Nuts & Wheel Valves
2007 Truck Wheels, Lug Nuts & Wheel Valves
2008 Truck Wheels, Lug Nuts & Wheel Valves
2009 Truck Wheels, Lug Nuts & Wheel Valves
2010 Truck Wheels, Lug Nuts & Wheel Valves
http://www.dodge.com/bodybuilder/201...tro/twlnwv.pdf
2011 Truck Wheels, Lug Nuts & Wheel Valves
2012 Truck Wheels, Lug Nuts & Wheel Valves
2013 Truck Wheels, Lug Nuts & Wheel Valves
http://www.rambodybuilder.com/2013/d...tro/twlnwv.pdf
Old 11-08-2013, 02:37 PM
Thanks
If you have the sport chrome clad ones….they are approx 32-34lbs and they are 20x9, 19.05 back space
Old 11-09-2013, 06:41 PM
BlownGP's Avatar
BlownGP BlownGP is offline
Vehicle: 2009 RAM CC Sport
Color: Sunburst Orange Pearl
Rep:15
BlownGP is on a distinguished road
Originally Posted by TheSatinPumpkin View Post
Here you go.
I was going to post that...
The best wheel upgrade is the R/T 22s. Just a few pounds heavier than stock.. Just mad $$$$$$$$$$$$$$$$$$$$$$$$$$$
98 GTP-Mods? Yeah, lots of them
2009 Ram CC Sport- Mods very SOON!!!
