Old 12-01-2012, 10:55 PM
98blackram 98blackram is offline
Vehicle: 1998 dodge ram
Trim Level: lariat
98blackram is on a distinguished road
Default help! 4 wheel drive wont lock in!
My front axle wont "lock" into 4 wheel drive. the light on the dash used to come on and now it won't. Plus i know the front end isn't "locking in". I shift to 4 lo and you can tell the transfer case is reducing down but only the back axle is spinning out and you can tell there is no help from the front end.
Where do i start? is there something common that usually goes wrong?
Old 12-01-2012, 11:47 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
panhead will become famous soon enoughpanhead will become famous soon enough
Start out by looking at the vacuum lines going to actuator on the axle. Make sure you have no vacuum leaks. Report back.
Keep it Mopar, buy Mopar Parts.
I am completely disgusted every time I think about having to take a distributor cap off of one of these trucks -Screamintrashcan
Old 12-02-2012, 01:15 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Concur with PanHead,please spend an extra moment with the drivers side of the transmission crossmember, where the 2 tubes are connected to the orange silicone coupler pieces.
Old 12-02-2012, 07:49 PM
Dodge Boy13's Avatar
Dodge Boy13 Dodge Boy13 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:23
Dodge Boy13 is on a distinguished road
i have the same exact problem! i used it to get home from school in the snow then i went to leave my house and nothing.... im pretty stumped in 4 low when i go to take it out it grinds but 4 high nothing happens
My Build Thread!!
http://www.ramforumz.com/showthread.php?t=118514
Old 12-02-2012, 11:48 PM
Color: 1 Blk,1 Red
Rep:36
DodgeBoy, that doesn't sound good, in your transfer case.
Old 01-02-2013, 01:19 AM
bfsoper's Avatar
bfsoper bfsoper is offline
Vehicle: 1997 Dodge Ram
Color: rhino lined black & custom green
bfsoper is on a distinguished road
ill tell you what man... i just had this happen to me, before looking @ the most obvious things first, i was thinking transfer case, actuater switch, vacuum issue, anything... but then when i went to lift all 4 tires off the ground to see whats moving & whats not... i happened to glance @ the axle shaft on the driver side... i had sheered the whole area where the u-joint connects the axle shaft & wheel hub... im lookin @ about 400$ to replace it. i broke it trying too hard to get out of a ditch, turning the wheels too much (binding the axle) & rompin on the gas too hard in 4lo. not to say thats your problem, but a friend of mine said if you do what i did, theres a 90% chance that will happen. So check it out, look EVERYTHING over, make sure nothing OBVIOUS is broken or out of place. & good luck to you bro!
BIGGER, better, LOUDER, ShWeEeEeEeT!!!
Old 01-03-2013, 06:01 PM
Rep:23
4 low worked the other day but of course after i was out of getting stuck..i think its a small vacuum leak because it works and then it doesnt...but im putting in posi lok for 150 bucks it bypasses the vacuum
http://www.4x4posi-lok.com/app_dodge.html
My Build Thread!!
