Old 01-01-2013, 04:02 PM
HemiRhoid's Avatar
HemiRhoid HemiRhoid is offline
Vehicle: 2012 Dodge Ram 4X4 RCSB
HemiRhoid is on a distinguished road
Default Tube Steps and Mud Flaps Rubbing
I installed Husky mud flaps shortly after I got my 2012 Express RCSB and installed Westin Platinum Tube Steps today. With the steps mounted toward the rear as far as possible, the edge of the support still rubs against the mud flaps in the front. I don't mind the rubbing but I'm sure it'll eventually wear a slot in the mud flaps. Has anyone else had this issue?
2012 Ram 1500 Express 4X4 RCSB
Extang Full Tilt Tonneau Cover; Herculiner Bed Liner; Husky Mud Flaps; Sylvania Silverstar zXe Headlight Bulbs; Westin Platinum Series Tube Steps; CIPA 36600 Rearview Mirror w/ map lights, compass, & auto-dim; Tow Hooks; AMI 6" Stubby Antenna and K&N Drop-In Air Filter
Old 01-01-2013, 06:02 PM
EXPRESS25C's Avatar
EXPRESS25C EXPRESS25C is offline
Vehicle: 2012 Dodge Ram Express RCSB
Trim Level: RCSB - Express 25C
Color: Diamond Black
Rep:83
EXPRESS25C will become famous soon enough
Sorry to hear about your problem, it's always the little things that seem to mess up an otherwise good Mod. I have the Mopar OEM mud guards and Steelcraft 4" oval nerf bars on my RCSB. There is about 3/4 inch between the bar and mud guard, no rubbing. Is it possible you can adjust your set up? Otherwise you might need to get different flaps. Good luck.
"Excess is Best"
Old 01-01-2013, 08:32 PM
HemiRhoid's Avatar
There's a little bit of adjustability toward the front and back and it's back as far as it will go.
Old 01-03-2013, 03:08 PM
NRose NRose is offline
NRose is on a distinguished road
I had to go with the full size mud flaps inside the fenderwell. I went with the drill-less installation by DuraFlap. They really keep my truck clean and chip free.
