United Radio
Old 02-27-2013, 01:37 PM
Divi Divi is offline
Vehicle: 2011 Ram 1500 Crew cab
Trim Level: Sport, loaded
Color: Obsidian Black Pearl
Rep:112
Divi will become famous soon enoughDivi will become famous soon enough
My dealer made not to check the date on the instructios as there are new corrected instructions out. I havent done the install yet but will keep this thread in mind when i do go to install if i have issues.
2011 Ram 1500 crew OBP, Airraid Cold air, Bestop roll up, Lockpick v5, custom carbon interior trim.
Old 02-27-2013, 07:46 PM
Tack's Avatar
Tack Tack is offline
Vehicle: 2011 Ram Sport
Trim Level: sport
Tack is on a distinguished road
If you are just getting your dealership to flash/reprogram the deck, after you install it, make sure they dont hose you on the labour.
I was quoted $70 and they are trying to charging me $108 @0.8hrs labour time... they had my keys for under a hr. and they didnt exactly jump on it like a pit crew.
Edit: so after a chat with the manager I am getting a $25 rebate.
Old 02-28-2013, 05:12 PM
Rep:112
just read my newer instructions and it states you have to use the white connector that is supplied in the kit. Glad i havent done mine yet i would have probally just used the one thats in the truck.
Old 03-01-2013, 10:20 AM
PJRNM's Avatar
PJRNM PJRNM is offline
Vehicle: 2012 Ram 1500
Trim Level: SLT Bighorn
Color: True Blue
Rep:17
PJRNM is on a distinguished road
Originally Posted by Razorback View Post
Comes with a disc, but there is a link here...
http://moparonlineparts.com/1500-pro...em-p-2516.html
I just received the kit with the CD. I need to compare the version I have on CD, with the version on the link above. I have a 2012 Ram 1500, can anybody verify the correct installation procedure in reference to the connectors and pins?
Old 03-01-2013, 10:44 AM
Rep:112
I found the version on the cd is the old version, ahould use the version in the link.
Old 03-03-2013, 12:02 PM
PJRNM's Avatar
Color: True Blue
Rep:17
Looks like I got the 'new' version on the cd. On the bottom of the pages it indicates:
Dec 01, 2010 K6869459 Rev. 2
Please advise if anybody possesses a newer version.
I have installed the new tailgate latch, I plan to run the wires next weekend.
Thanks!
Old 03-03-2013, 12:16 PM
Rep:112
i found that the instructions dont help, i found that the wires they want you to tap are not there. been searching the interwebs trying to find a wiring diagram to figure out the correct place to tap.
Old 03-14-2013, 11:29 PM
PJRNM's Avatar
Color: True Blue
Rep:17
Brown plug, WH/R wire. The wiring diagram actually shows that, not WH/LG as it says in the text....and it's not in either of the indicated slots.
Can anyone verify what color wire and what slot the reverse wire is on a 2012 1500? I'm going to tackle this tomorrow!
Thanks
Old 03-22-2013, 08:24 PM
PJRNM's Avatar
Color: True Blue
Rep:17
All done and working!! I can verify that the reverse lead is the brown plug, WH/R wire. One other shortcut I can offer is, DO NOT cut the nipple for access into the passenger compartment. If you have an automatic, just drill through the plastic plate that is placed where the clutch slave would have been mounted. Just drill the hole in the middle and run your wire. I also sealed around the wire with silicone for a good moisture barrier. If you have the lockpick, you DO NOT have to go to the dealer to have the radio flashed. Even if you use the stock radio plugs, not the RCA plugs, the camera will work when wiring is complete!
Hope this helps.
Old 04-04-2013, 10:56 PM
PJRNM's Avatar
Color: True Blue
Rep:17
The correct connector:
A close up:
The wires leading to the back up lamp showing the WHT/RD wire:
