Old 01-02-2013, 10:21 AM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
Default Friend's Durango...Need help
I have a friend with an 05 durango. I don't know which engine but I know it is a V8 but not a hemi.
There is a light on the dash which the manual says is an emissions malfuntion light.
The truck will idle high then drop a few times then die and not start again for a while.
What could be causing this? I am trying to help this guy out with this one.
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
Old 01-02-2013, 12:14 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:215
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
My bet is he has the 4.7L and it is the IAC or TPS
Id replace the TPS first (Trottle Position Sensor)
Mike
Old 01-02-2013, 12:17 PM
sonocativo's Avatar
Rep:215
also if it will run/drive, get it to autozone or oriellys and have them to do a code scan to see whats showing up unless you can get the codes with the key/dash light sequence.
Mike
Old 01-02-2013, 12:23 PM
Rep:1890
Throwing parts at one without so much as first pulling codes is foolish. A failure of either of these parts isn't likely to result in a no start condition.
Old 01-02-2013, 12:25 PM
Rep:1890
The engine is a 4.7. I've never heard of anything called an emissions malfunction light. Malfunction Indicator Light, perhaps? If this is illuminated, it indicates codes are stored in the PCM that need to be checked.
Old 01-02-2013, 01:12 PM
Color: tan
Rep:65
I didn't know if you could read codes without the actual CEL on. I told him to go get the thing read so maybe we will have an answer soon. He works an odd schedule so I am going to try to catch up with him later in the week. He has had his driving handles and such installed and that could be messing with something since they weren't "professionally" done.
Old 01-02-2013, 01:29 PM
Rep:1890
The light will go out after 3 complete, fault free drive cycles but the codes will remain stored until 40 cycles are complete without the code popping back up. Can't say I'm familiar with "driving handles".
Old 01-02-2013, 01:34 PM
Color: tan
Rep:65
The handles...He is pretty much without the use of his legs, so he drives with the handle. I don't know the real name of them and am not smart enough to look it up...LOL!!! I get what you are saying about the codes, I will get them read and see what I can find. Thanks!!!
Old 01-02-2013, 01:37 PM
Rep:1890
Oh, handicap hand controls. Unless something was damaged during the install, such as pinching a wire, I really don't see that being an issue.
Old 01-07-2013, 11:56 AM
sonocativo's Avatar
Rep:215
There are possible wires under the floormat where the controls are mounted that may have gotten damaged if someone who is not real familiar with the vehicle installed them, Try the codes first, them back track to when the problem started.
Mike
