Old 01-02-2013, 10:50 AM
jtheruler79 jtheruler79 is offline
Vehicle: 2012
jtheruler79 is on a distinguished road
Default Mygig questions
I have 2012 Ram ST and looking from going from the RESS to a Mygig. Can someone point in the right direction on which part number I should get? I believe its one of the following:
P05064678AF
P05064678AH
What are the differences between the two? I would like the newer version that is Ipod ready. Also, these are plug and play, correct?
Old 01-07-2013, 01:12 PM
Scotty85's Avatar
Scotty85 Scotty85 is offline
Vehicle: 2012 Dodge Ram
Color: True Blue Pearlcoat
Rep:79
Scotty85 will become famous soon enough
Not exactly sure about the part numbers. Ironically, I do have a complete 430n navigation system for sale. (the Alpine system) Everything including the HU, amp, headliner/dash/door, and subwoofer speakers. PM me if you're interested. Should be plug and play. As far as I know, the only thing you would need is the GPS adapter.
Scott
2012 RAM Sport CC Hemi - Photos here:http://www.ramforumz.com/showthread.php?t=132968
Audio Mods - http://www.ramforumz.com/showthread.php?p=1005034
Perf. Mods - http://www.ramforumz.com/showthread.php?p=1005080
Body Mods - http://www.ramforumz.com/showthread.php?p=1005083
Old 01-10-2013, 03:57 PM
Socalgordon Socalgordon is offline
Vehicle: 2014 Dodge Ram 1500
Trim Level: Big Horn Crew Cab
Rep:126
Socalgordon will become famous soon enoughSocalgordon will become famous soon enough
Any mygig 430 (RBK), or 430N (RHB) or 730N (RHR) will work fine. Do not worry about the part numbers that much. As long as you have a radio that is made in late 2010 and up, you will be fine--- PROVIDING that the radio is a HIGH SPEED BUS version and NOT the low speed version. My radio(s) I had in my truck (430, 430n, 730n) each one came from a different model, ie, Jeep, Durango. There are other mygigs 430 (RBK), or 430N (RHB) or 730N (RHR) that are older made before late 2010, the reason why I recommend a radio that is made as CURRENT as possible, is that for some 2010, all 2011 and 2012, the radios themselves had a software AND HARDWARE change that allowed for some new features that are NOT in the older mygigs. ie, replay (rewind/pause) satellite radio being the big change.
As long as the radio is High speed and the screw mount holes are on the side of the radio and not on the top and bottom (made for some jeeps and other Chrysler models), you will be fine. Simple unplug and plug back in, you are ready to go.
When you see a radio online (Ebay) pay attention to the sticker on the top of the unit. It will tell you the day, month and year it was built.
If you try to go by the part number alone, you will go insane as I found part numbers on my old 430N radio to not show up anywhere online. But it worked!
