Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 01-02-2013, 04:57 PM
08Dram1500 08Dram1500 is offline
Vehicle: 2008 Ram 1500
08Dram1500 is on a distinguished road
Default Cruise Control issues??????
I recently replaced both front hub assemblys on my 2008 dodge ram 1500 4.7L and now my cruise control works only between 30mph-40 and 55-65mph, anywhere outside that range and the cruise light wont even turn on? i had to use all the old wiring when replacing the hub assembly because the new connector on the hub assembly didn't match up to my original wiring but all that looks fine? I have no idea what could be doing that, i would assume the wiring or connectors not being put on well, tonight i'm gonna take a more detailed look and see if i can hopefully fix it. i would appreciate any opinions or help!
Old 01-03-2013, 12:01 PM
Resident Technician
Rep:1915
Got any speed sensor codes in the ABS module or PCM?
Old 01-05-2013, 10:28 PM
Ill take the truck to auto zone and have them use the scan tool and see what they can find out?
Old 01-08-2013, 08:38 PM
namccanna's Avatar
namccanna namccanna is offline
Vehicle: 2013 Dodge Ram 1500 SLT
Trim Level: SLT Big Horn Edition
Color: Black & Chrome
Rep:50
namccanna will become famous soon enough
How did you retrofit your old wiring on the new hubs? From my understanding of the speed sensor is that it is basically permanently attached to the hub assembly. My GUESS would be that this retrofit would be the issue.
If the new hub connections don't match your truck's connections, I would question the parts store where you purchased them if they are the proper hub assemblies. The aftermarket hubs should match your truck!
I WELD FOR MONEY! IF YOU WANT LOYALTY.....BUY A DOG!
Old 03-10-2013, 10:53 AM
There is a male piece and a female piece on wiring with old hub assembly wiring to attach to vehicle wiring(sensor wiring), the male piece on the new assembly would not fit into the female piece on the vehicle wiring so i just cut a piece of the wiring out of the old hub assembly with (proper male piece) and then put that onto new hub assembly wiring. so the new hub assembly had the proper fitting now to just put together. the male and female pieces i'm speaking of are plastic pieces, sensor connections. I would have to agree that the retrofit must be the issue but it still puzzles me as to how the cruise control is working at certain speeds just fine but not working at other speeds whatsoever? I completely agree with you again, i was in a rush and impatient father was helping with vehicle so we just worked with what we got. The hub assembly them selves matched fine, it was just the cruise control sensor wiring connection didn't match up with the new one.
