Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-02-2013, 05:10 PM
FilthyDog's Avatar
FilthyDog FilthyDog is offline
Vehicle: 1999 Dodge Ram 1500
Trim Level: SLT Laramie
FilthyDog is on a distinguished road
Question Thermostat Installation/ over cooling
I recently installed a new 195 thermostat which came included with a Hughes Plenum kit. Now my truck ('99 1500 5.9) only reaches an operating temp of 140 F. Dashboard gauge and infrared thermometer both read 140.
When I was draining the coolant for the Plenum job it came out clean.
Is there anything else I should check before I come to terms with the fact that I got a bad thermostat out of the box?
Could I have installed the thermostat wrong? it is my understanding that if you install the thermostat upside-down then your truck immediately overheats.
Thanks,
Filth
Mods: Hughes FI Intake, Stainless Steel Short Headers(generic ebay), Rebuilt Cylinder Heads, K&N Cold Air Intake, IAT Mod, Hughes STAGE 1 MODIFIED O.E.M. THROTTLE BODY, High Flow exhaust, LineX Bed Liner
Old 01-02-2013, 05:38 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
yeah that seems odd. Truck should be getting significantly hotter than that. How long are you letting it run? How cold is it outside?
Sean
Old 01-02-2013, 05:43 PM
FilthyDog's Avatar
Today I let it run 15 min before I used the infrared thermometer. It's about 30F outside.
Old 01-02-2013, 05:46 PM
snrusnak's Avatar
Rep:1385
Ok you need to run it longer than that probably, in that temp anyway. Are you just letting it idle in the driveway, or actually driving it? On a cold start and idling in the driveway, my truck will not get up to operating temp in 15 minutes, even in florida summer heat.
Sean
Old 01-02-2013, 05:54 PM
FilthyDog's Avatar
Hmmm... I'll go check again. right now.
Also, should the fan run continuously? or should it cycle on and off?
Old 01-02-2013, 06:47 PM
FilthyDog's Avatar
Alright, I just let the truck run for another 30min. It is not reaching full operating temp. Just as when I drive to work, the dash indicates that the temp only gets to ~150 and a hand held thermometer reads 140.
Old 01-02-2013, 10:44 PM
snrusnak's Avatar
Rep:1385
Ok, so you are in fact actually driving it then? On a 15 to 30 min drive I'd think it should get up to temp.
Do you have an electric fan? If you have a clutch fan it will always spin, but will only have the clutch engaged above a certain temp(around operating temp).
Sean
Old 01-03-2013, 10:44 AM
FilthyDog's Avatar
Yes, in all cases, the truck does not reach 195F
Old 01-03-2013, 10:45 AM
snrusnak's Avatar
Rep:1385
You have a factory clutch fan, correct?
The tstat could be bad, maybe stuck open or something.
Sean
Old 01-03-2013, 11:13 AM
FilthyDog's Avatar
Yes I have a factory clutch.
I'm almost positive that I have stuck thermostat. I'm just wondering if I should check anything else before I replace it. Or, if there is any way to free a stuck thrermostat with out removing it.
thermostat
