Old 01-02-2013, 09:28 PM
rem300wsm rem300wsm is offline
Vehicle: 2007 dodge ram 2500
Color: grey
rem300wsm is on a distinguished road
Default revtek two inch coil spacers any good
Putting them on a 2007 dodge 3/4 ton to get it riding level, will they hurt anything in the front end, and what is a ballpark price for a mechanic to install them. Thanks.
Old 01-02-2013, 09:36 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
Do it yourself. Real easy to install. Probably take the shop 2 hours to install plus the alignment. But all you need to do is compress the front coil and put the spacer on. Real easy. I installed the one on my 06 Mega Cab 2500, 03 2500, and 06 QC 2500
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 01-04-2013, 06:02 PM
Color: grey
So thats all you have to do is just compress the coil lift the front end up a little and slip the spacer in, you dont have to take apart some front end parts before.
Old 01-04-2013, 06:13 PM
Ram725's Avatar
Rep:347
I mean on my 06 Mega Cab thats what I did because I had a coil compressor. Had to remove the tire of course. But usually you remove a few other front end parts but either way its still an EASY install. Even if you discount half the stuff up front its very easy.
Build Thread
Old 01-04-2013, 06:26 PM
Color: grey
So you mean if i have a coil compressor.
Remove tire
Undo bolts on top
Compress coil
Slip spacer in
Tighten bolts
Replace tire
DONE
And i can skip messing with the front end parts. I AM NOT MUCH OF A MECHANIC. Thanks.
Old 01-04-2013, 06:28 PM
Ram725's Avatar
Rep:347
I am pretty sure you can. Thats what I did on my 06 Mega Cab. I used Pro Comp. It literally is just a spacer... I mean you'll need to take it to get an alignment probably. But yes it is very easy. Google spacer install in a 3/4 ton Ram. But yes, very very very easy install. Don't pay someone to do it
Build Thread
Old 01-04-2013, 06:34 PM
Color: grey
Ok thanks ill give it a try.
