Old 01-03-2013, 12:00 PM
bix409 bix409 is offline
Vehicle: 2002 ram 1500
Trim Level: sport
Color: silver
bix409 is on a distinguished road
Default engine idles high or wants to stall
I have an 02 1500 with a 360 that idles either around 1500 to 2200 rpm or wants to stall. put a IAC in it but still all over the place. checked for vac leaks to no avail. I put a TPS in it a year ago that stoped the shifting issue but this about has me beat. Could it be a MAF sensor or dirty throtle body? Any tips?
Old 01-03-2013, 03:33 PM
Resident Technician
Rep:1909
You don't have a MAF sensor in your truck. This could be an internal vacuum leak caused by a blown plenum pan gasket. How did you check for an external vacuum leak?
Old 01-03-2013, 05:04 PM
Trim Level: sport
Color: silver
Default high idle
I checked for any broken or loose hoses. Then sprayed carb cleaner at anything suspect. Problem is it wasnt running poorly at the time i did it and i heard no differences. I ment MAP sensor not MAF sensor sorry. I want to rule out whatever i can maybe even get a new TPS. Also i have been smelling coolant but no leaks found. Not sure if a intake gasket would have anything to do with it. No loss of power.
Old 01-03-2013, 11:22 PM
major324's Avatar
major324 major324 is offline
Vehicle: 1997 dodge Ram 1500 2WD 5.9
Trim Level: sport
major324 is on a distinguished road
A widely passed over vaccum leak is the brake booster and also the intake pan gasket as it is so common with these engines and I would start by checking your voltage both in and out of your TPS as it would help rule it out. It can get pretty expensive randomly changing sensors.
Old 04-08-2013, 03:27 AM
Crca32 Crca32 is offline
Vehicle: 2000 1500 dodge ram
Trim Level: Slt
Color: Blue
Crca32 is on a distinguished road
Did find out was what going on my does the same thing
