Old 01-03-2013, 02:12 PM
johnnyclack johnnyclack is offline
Location: On the banks of the Clackamas River, Eagle Creek OR
Vehicle: 2002 1500
Trim Level: basic
johnnyclack is on a distinguished road
Default 02 <>96 4.7 Swap; Newbie here today. I jumped on from the 1979 K-30 Chevy-GMC forum
I have a young friend w/02 1500, hit some ice & slammed the front into a tree. Took out the front sheet metal clip, smashed the lower core support cross member and frame horns back to the torsion bar mounting supports. Frame appears to be tweaked from drivers side to pass side (area of greatest impact damage). WP, radiator, and condenser are intact. The truck is currently wired together, coolant reservoir is ty-wrapped to the upper radiator hose and the truck (02) is currently running on the road.
The kid has located a 1996 1500 donor truck {also 4.7 v6}. Cab/ chassis & running gear appears intact. Engine is froze. PO picked up the truck for bed/box & relocated it to his 2500. Now is wanting to pedal remains.
The “Question”
1. Do I help him cut-fit-weld the 96 frame to the front of his 02, and use the 96 front clip ? (not too excited about trying to straighten out tweaked frame….)
2. Or do I pull the engine & transmission from the 02 in place it in the 96 frame ? as well as bed/ box.
From what I understand, I have not seen donor vehicle, they are comparable in terms of shape /condition, with maybe a few interior components needing changing out.
The last question I have in this post is: Can the engine and transmission be pulled as one unit or are they pulled separately “Which is easiest/ “
Last edited by johnnyclack; 01-03-2013 at 02:13 PM. Reason: screwed up engine size
Old 01-03-2013, 02:15 PM
Vehicle: 2002 1500
Trim Level: basic
OK it's a V6 which I guess... does not make it a 4.7, hellifIknow>>>>
Old 01-03-2013, 02:36 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
4.7 is a V8. Would it not be better to use the parts off the 96 and just get the frame straightened at a body shop? Not sure if all the computers would have to be swapped if he did motor swap, but it sounds like a big job and a nightmare, whereas fixing body and frame sound more straight foreward. Hopefully someone that has done this will answer.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 01-03-2013, 07:30 PM
HemiLonestar's Avatar
Rep:274
FIRST of all...you have conflicting info. Is it an 02 1500 or 2500? A 96 should have a 3.9 V6 or a 5.2/5.9 V8. Need straight facts.
"Big Red"
2006 Charger R/T
Old 01-03-2013, 08:38 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^what he said.
A 1996 and a 2002 are different generation trucks, basically nothing is interchangeable.
Sean
Old 01-06-2013, 10:03 PM
Rep:274
Unless its a 2500, then 3/4 & 1 tons went all the way to 2002 before the body style change.
"Big Red"
2006 Charger R/T
