Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 01-03-2013, 06:07 PM
Goobz Goobz is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: Laramie SLT
Goobz is on a distinguished road
Send a message via ICQ to Goobz Send a message via AIM to Goobz Send a message via MSN to Goobz Send a message via Yahoo to Goobz Send a message via Skype™ to Goobz
Default Heater blower stuck on top vents
Hey all...
Quick ?.. The heater has always functioned in my `98 1500. However, today it is stuck on the top vents, and won't change regardless of what I put the vent dial on. The temp and fan speed work, but not the vent selection.
What is HAS been doing lately, is when I gun it, or put the motor under a load, no matter what the dial setting is on, it always shifts to the defrost vents for a few seconds, then back down once I back out of it.
Any suggestions? Thanks!
Old 01-04-2013, 09:16 AM
Rep:1877
You have a vacuum problem. For starters, the check valve is probably bad and you may have even lost your vacuum source completely. Check the vacuum line going from the engine to the heater box for a problem.
Old 01-04-2013, 05:11 PM
I take it the vacuum line you are refering to is the one that is off the driver side of the manifold, that T's off the Cruise Control, then goes in to the firewall over by what looks like the A/C lines? That is still there.
So I would assume it is the other piece you are talking about. Where is this located, and is there an easy way to test it?
Old 01-04-2013, 05:44 PM
Rep:1877
That's the one. If you have a good vacuum supply and the line is intact, it's time to go into the dash and look for a problem there.
Old 01-07-2013, 03:21 PM
shot shot is offline
Vehicle: 1986 Ram Charger 150 Royal SE
Trim Level: SE
Color: Dark grey/Silver
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
shot is on a distinguished road
What might we be looking for under there ? I replaced the radio on my 1985 and while under the dash I saw some multi-colored tubes with what looked like some OLD yellow plastic pieces hanging on them. Didn't have enough form to figure out if it was blanked off or needed to plug into something. Would this be connected with the ventilation controls? Anyone know of a schematic for that system ? thanks
Old 01-07-2013, 03:28 PM
Rep:1877
This is for a 1986 D150.
Old 01-07-2013, 08:04 PM
Trim Level: SE
ooooohhhhh.....there goes my Saturday. So the numbered connector block goes to the back of the control panel ? Thanks for the drawings
Old 01-07-2013, 08:26 PM
Rep:1877
Yeah, it should be plugged into the back of the control head.
Old 01-09-2013, 06:09 PM
Well, everything on mine works fine. Aftermarket stereo (replaced about a year ago), heater controls for temp and speed, etc. The only thing that doesn't work is the ventilation switching.. However.. I can almost guarantee it's not the switch or connector, because if I actually select the Defrost or A/C, I can hear the compressor clutch kick in, and when I turn that function off, the compressor stops.
So I guess I'm just curious as to what piece it could possibly be...
Old 01-10-2013, 03:07 PM
Trim Level: SE
Hey Ram Tech........every time I come to this page a different picture appears.Did U set that up that way? I printed out the ventilation controls drawing but when I try to look at it from another pc it advances the picture. Thanks for info !
a/c problems, blower, fan
