Old 01-03-2013, 08:22 PM
Kidkrylon73 Kidkrylon73 is offline
Vehicle: 2012 ram 1500 sport
Kidkrylon73 is on a distinguished road
Default Questions about alignment
Hey everyone, I have a questions about my 2012. I recently installed a Rough country leveling kit. Than I just had 35x12.50x22 in wheel and tires installed. Before the alignment was done the the steering wheel was only slightly turned to the right. and the truck didnt really pull too hard at all. Now after getting the alignment, the steering wheel is still turned to the right but a little less now. Only now the truck pulls more to the right, and dives into right hand turns, but I have to put more effort to go left. Not a ton but it doesnt dive like it does going to the right. I looked at the alignment numbers and they are almost right on factory settings. maybe a degree off on one or two angles. But almost right on.
Anybody got any ideas on how I can have this adjusted or why this is occurring.
Thanks Joe
Old 01-04-2013, 12:23 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
Balancing issue maybe??
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 01-05-2013, 12:24 PM
Greg50Lt's Avatar
Greg50Lt Greg50Lt is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
Trim Level: Sprot
Rep:20
Greg50Lt is on a distinguished road
I have the same issue but to the left. Ive had my tires re balanced twice and also had the alignment done by two different shops. Still comes back the same. Mine isn't bad under 55mph if I hit 70mph on the freeway it gets really bad. It'll actually take left hand turns by itself.
I have TGC spacer in the front and rear
OE: Nav/Alpine, Backup cam, brake controller, side steps Aftermarket:Bedliner, Tonnopro bed cover, Windows 20% Tails and Cab light tinted, 18in Magnaflow, Black Fuel Hostage 20x9 trail Grapplers 295-60R20, TGC 2.5 front spacer .75 rear, Billet fuel door
Old 01-05-2013, 12:29 PM
Resident Technician
Rep:1909
Thanks Joe
I suspect an incorrectly done alignment. I presume they didn't give you a before and after spec sheet. It sounds to me like you have a cross caster problem (either too much in the left or not enough in the right) but it could also be a camber related problem or even a little of both.
Old 01-05-2013, 03:51 PM
OMALLEY808 OMALLEY808 is offline
Vehicle: 2009 Dodge Ram SLT
Color: stone white
Rep:64
OMALLEY808 will become famous soon enough
Double check your air pressure in your tires too!
