Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 01-04-2013, 12:09 AM
blue beast's Avatar
blue beast blue beast is offline
Vehicle: 2011 dodge ram
Trim Level: express
Color: blue
blue beast is on a distinguished road
Default 2011 4.56 gears
does anyone know exacty what has to be modded on our cairer to run 4.56 gears?
Old 01-04-2013, 09:00 AM
Jmac86201's Avatar
Jmac86201 Jmac86201 is offline
Trim Level: Grey
Color: Grey
Rep:15
Jmac86201 is on a distinguished road
PM Candy08, he has them on his 2011, and knows a ton of information on this subject.
Old 01-05-2013, 02:43 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
You'll need to machine the rear diff to accept the bolt pattern of the gear. This is for the rear. The front is a straight swap
sales@revelperformance.com
Old 01-06-2013, 02:45 AM
blue beast's Avatar
Trim Level: express
Color: blue
ok when you say "machine" is this something that can be done with a drill and a bit? or a grinder? do i have to make new holes or am i trying to machine to make the ring gear fit against the cairer flush. i see you have them in your truck so any help would be greatly appreciated.
Old 01-06-2013, 04:10 AM
Rep:2804
from what i understand, its a re-drill & fill process
like what you would have to do when changing axles from ford to chevy pattern
i think another way would be to change the whole carrier assembly, but i may be way off
Old 01-06-2013, 12:00 PM
Revel Performance
Rep:1804
You need to either be a machinist or have it machined to have the ring gear fit the carrier.
As it stands right now. The ring gear holes do not line up with the holes present on the carrier.
Once it's machined to line up with Ye ring gear holes, you are then able to bolt them in as normal.
This is not a huge deal. Just need the right shop, right equipment or simply the know how to do this.
Old 01-06-2013, 12:47 PM
htownrock htownrock is offline
Vehicle: 2012 dodge ram express
Trim Level: express
htownrock is on a distinguished road
I Think Moe's sells the whole setup carrier with 4.56
Old 01-06-2013, 01:01 PM
Revel Performance
Rep:1804
If he does, that's perfect.
But he would have to have the carrier from an 09/10.
11/12 have the ZF axle which is what makes it different.
Old 01-06-2013, 02:46 PM
blue beast's Avatar
Trim Level: express
Color: blue
thanks for all of yalls help.
Old 02-08-2013, 07:49 AM
Dragpac's Avatar
Dragpac Dragpac is offline
Vehicle: 2013 dodge ram
Rep:33
Dragpac is on a distinguished road
Im going through it,i added a tru trac posi and 4.56's but i needed to get one new axel because the stock axels are 2 different lenths.with my new setup they need to be the same.
The axel is $280 from dodge so the total will be about $1300 complete with gears,posi and axel.
[SIGPIC]
]2014 sport crew cab hemi 8 speed 3.92 gears
