Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-04-2013, 08:50 AM
Gharlan1 Gharlan1 is offline
Vehicle: Ram 2000 dodge
Color: Sliver
Gharlan1 is on a distinguished road
Default Coolant not flowing into overflow tank PLEASE HELP
Coolant is building pressure and blowing out everywhere I found out that coolant isn't flowing into the overflow tank and I don't know why
Old 01-04-2013, 08:59 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Where's it blowing out from? Radiator cap could be bad(cheap to replace). Check the hose leading from the radiator cap to the overflow tank as well, it could be blocked(also cheap to replace). Other than that it should work fine.
Sean
Old 01-04-2013, 09:08 AM
Color: Sliver
Changed the cap, still doing it and idk where it's blowing out from because its everywhere so up can tell where's it coming from
Old 01-04-2013, 09:10 AM
snrusnak's Avatar
Rep:1385
Start with removing the cap(when cool) and seeing if water will flow through the overflow hose from the radiator to the tank. If that's blocked up then just replace that line.
Sean
Old 01-04-2013, 09:43 AM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
Radiator hoses will wear out and collapse due to the vaccumn affect of the water pump. If any hoses look sucked in, replace them.
Other thing that comes to mind, mineral build up from using tap water will clog the radiator.
My first thought was the radiator cap as well. Go ahead and replace the thermostat, hoses and have a radiator shop clean/flush and pressure test your radiator. It's not expensive if you do the work yourself.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 01-04-2013, 09:58 AM
Resident Technician
Rep:1909
Here's a thought - is it overheating before it does this? If so, you should consider a stuck thermostat.
Old 01-04-2013, 12:44 PM
Color: Sliver
The truck isn't over heating but its the water pump we used a pressure tester and it showed a constantly leak under pressure I'm gonna also flush the system so it will run into the overflow tank if needed
coolant, leak, overflow
