Old 01-04-2013, 02:23 PM
olds442111 olds442111 is offline
Vehicle: 2011 Big Horn Ram
olds442111 is on a distinguished road
Default TPMS woes
So a few hundred miles back, the Service TPMS message came on, and the indicator lamp began flashing. The lamp then remained on steady after a little while. Where the right rear pressure should be indicated was a simple "--". A few miles down the road, its all back to normal. This has been going back and forth for several hundred miles. Took it to the dealer, who changed the sensor in that wheel. Still, the problem persists. Appointment made for 8am this morning. Got there at 7:30, and while driving there, the light and message stayed with me. Dealer saw it doing this firsthand. Today, after 4 hours in the service dept., they explain they have manually entered the sensors in, and the light should reset itself after I get on the interstate to come home. Ok....whatever. I drove it home. Message and light stayed with me the whole trip, which is about 40 minutes at 75 mph. Never had to stop. This will be the 3rd trip to the dealership for this same issue. I just want the truck fixed. Anyone have any ideas? I'm a technician for Toyota / Hyundai 13 years ago, so I'm afraid this system is something I have no knowledge on, but working on cars isnt green to me at all. I'm willing to fix it myself if I can pinpoint the issue. BTW, they clearly told me that the computer checked out good with the Chrysler computer they used on the truck. HELP!!!! Thanks
Old 01-04-2013, 02:52 PM
Resident Technician
Rep:1909
Sounds like it's time for a new Wireless Ignition Node (WIN module) if replacing the sensor didn't work.
Old 01-04-2013, 07:22 PM
I'm failing to see the relation of the WIN module to the right rear tire sensor. Can you elaborate a little on this?
