Old 01-04-2013, 02:09 PM
Texas8point Texas8point is offline
Vehicle: 2011 Dodge Ram
Trim Level: Texas
Texas8point is on a distinguished road
Default Headlight issue (Not the bulb)
My 2011 Ram has a passenger side headlight issue. The headlight went out, so I replaced it (I did not touch the glass). The replacement bulb went out and then came back on and so I replaced the buld AGAIN ! It continues to be an issue where the light will come on sometimes and then go out. Somtimes out for a couple of days, sometime off and on all day.
Old 01-04-2013, 02:25 PM
Rep:1885
It's time to stop messing with bulbs and to start looking to the TIPM for a problem. If that's what it is, your warranty should cover it.
Old 01-07-2013, 07:51 AM
Trim Level: Texas
I was hoping it was a connection issue..... but it doesn't flicker. Its either on or off.
I heard I may be able to unhook the battery for 10 or 15 minutes and it "might" reset the headlight switch !!!!
Old 01-07-2013, 09:02 AM
Rep:1885
What you heard was a rumor. The switch is just a switch and there's nothing to reset.
Old 01-07-2013, 11:08 AM
Stonednloaded Stonednloaded is offline
Rep:14
Stonednloaded is on a distinguished road
I had a problem similar to this when i hooked up my HIDs the prob was a bent or loose pin in the connection harness i think it was the green one with the funny connection you have to pull the pin before you can unhook it anyways if i squeezed that connection hard my light would come on took me a little bit of fooling around sometimes I had to pinch is several times but I would give it a try never know!
Old 01-07-2013, 01:23 PM
blackpearldodge's Avatar
blackpearldodge blackpearldodge is offline
Vehicle: 2011 Crew Cab 1500 Sport 4x4
Color: Black Pearlcoat
Rep:19
blackpearldodge is on a distinguished road
Same thing happened to me, but it was with the high-beams. I'd drive a day or two and then the light would go out. I'd disassemble the lights and fiddle with the bulb and harness. Light would come back on. Reassemble everything... drive a day or two and then the light would go out again. Was very frustrating. At first I thought it was the bulb (replaced), but the light kept going out. Finally figured out it was the harness. Looks like I have a loose wire/connector. I finally just plastic zip-tied the harness onto itself. Light hasn't gone out since. I should probably get it in under warranty...I have HIDs though and don't want the dealership knowing....
Once you have Black you'll never go back!
Sport Performance Hood, OEM Mud Flaps, Engine Cover (Hemi Orange), Factory Spray-in Bed Liner, 50 watt - 6000k HID Headlights (low-beam), 35 watt - 4300k HID Fog Lamps, LED License Plate Lights
Old 01-07-2013, 04:29 PM
Trim Level: Texas
This sound close to my problem ! Damn it !!!
Old 01-10-2013, 08:23 AM
Trim Level: Texas
day 3 with both headlights !!!!!
Old 01-10-2013, 11:12 AM
bluedodgeram's Avatar
bluedodgeram bluedodgeram is offline
Vehicle: 2011 Ram Sport 4X4 Crew Cab
Color: Deep water blue pearl
Rep:13
bluedodgeram is on a distinguished road
Talking
There is also a TIPM update also if this helps.
