Bilstein 5100 Leveling Before and After with pics - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-24-2014, 09:05 AM
hazard214 hazard214 is offline
Vehicle: 2010 RAM 1500 TRX4 4X4
hazard214 is on a distinguished road
Hey Rob, how's it going man. I'm new to the site and was looking for some help trying to install the bilstein shocks. I took it by an auto shop but they we're saying they could not get the spring perch off, and was wondering how you took that off if you did it yourself. Also if you did do it yourself do you know if the black cap ontop of the shock is removable? I included a pic showing the stock shock to the trx4. It's the black cap on top that will not let us take off the spring perch. Any advice will help. Thanks!
Old 04-25-2014, 02:07 PM
TruckBC TruckBC is offline
Vehicle: '14 1500 Outdoorsman on order
Trim Level: Outdoorsman
Color: Blue/Black Two Tone
TruckBC is on a distinguished road
I was under the impression that the bilstein shocks come with new spring perches??
I dont see why you'd have to remove the old one!
Old 04-25-2014, 02:10 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
The OE spring perch has to be used on the Bilstein shock
All that is provided with the Bilstien is the clip (that you adjust for height) that the spring perch sits on.
Many shops will say they cannot remove because of the shock dust cap, but that cap, can be knocked off allowing for you/them to remove it.
sales@revelperformance.com
Old 04-25-2014, 04:59 PM
robpayneusaf's Avatar
robpayneusaf robpayneusaf is offline
Vehicle: 2010 Dodge Ram 1500 TRX4
Trim Level: TRX4
Rep:205
robpayneusaf has a spectacular aura aboutrobpayneusaf has a spectacular aura aboutrobpayneusaf has a spectacular aura about
Exactly what fast said. It may take some doing, but the stock perch does come off.
Old 04-25-2014, 06:07 PM
Revel Performance
Rep:1804
Its the shock dust cap that throws off many. Take a screw driver or something with somewhat of a pointed edge and take a hammer/mallet to it and it will pop off
Old 01-26-2015, 10:04 PM
rwwillis rwwillis is offline
Vehicle: 2014 Ram ecodiesel
Trim Level: laramie
rwwillis is on a distinguished road
You said you had the shock set on 2.8(Front) but it showed only a 2" lift. Is that all the lift I can expect with the setting at 2.8?
Old 01-26-2015, 11:00 PM
Revel Performance
Rep:1804
No. You'll see between 2.5" on the low side to 2.6"
It won't settle that low
Old 01-27-2015, 02:56 PM
Tiger-truck Tiger-truck is offline
Vehicle: 2013 Hemi Crew 4x4 8 speed
Trim Level: Outdoorsman 6.4"Bed
Color: Deep Cherry Red Metallic/Mineral Grey Metallic
Tiger-truck is on a distinguished road
I'd like to see the cv angles as well. I have an Outdoorsman I'm about to put Bilsteins on and I'm debating the height.
For those interested, TRX and Outdoorsman sit almost 3/4 an inch higher than stock. So when you set the bilsteins at 2.8 you're gaining 2.1. If you sit a normal Ram with 2.8 bilsteins next to an Outdoorsman with 2.8 bilsteins the height will be the same. The regular Ram will have just gained more height to get there.
Old 01-30-2015, 03:51 PM
nToxik nToxik is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Color: True Blue Pearlcoat
nToxik is on a distinguished road
I have a 2012 Outdoorsman and I have purchased Bilstein 5100's for the front but haven't installed them yet. I have been flopping between the 2.1 and the 2.8 settings and thought I would go 2.1 but now you say that it will still have too much rake? I don't mind a little rake but I definitely don't want the truck being front high.
What causes the Outdoorsman to be 3/4 taller than other RAMS?
2.1 or 2.8? 2.1 or 2.8? ARGH.
Bilstein 5100s @ 2.1", BakFlip FiberMax tonneau
5100, bilstein, level, leveling, trx4
