Oil burning fast in 2000 Ram 1500 - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 01-18-2013, 01:54 PM
Resident Technician
Rep:1915
Originally Posted by elinmon1976 View Post
You can DIY the plenum gasket yourself if you are at all mechanically inclined. you can get out cheap by just replacing the gasket but the hughes kit will fix it right and no more problems most likely. BTW I have 220k on my 98 5.2
The correct replacement gasket is just as good a a Hughes kit and a lot cheaper.
Old 01-19-2013, 09:27 PM
1997 dodge ram 1997 dodge ram is offline
Vehicle: 1997 dodge ram 4 x 4
Trim Level: ram 1500
Color: green
1997 dodge ram is on a distinguished road
Hi I trust your truck has a 5.2 or 5.9 engine , and for how long they will run
mine has 360,000 kilometers on it and will not quit , I had a similar problem
when I first got the truck 3 years ago intake plenum gasket was the culpret
as well as using oil I had a high idle then , fixed it and no more .
Old 01-22-2013, 08:43 PM
Color: green
Default 318 5.5 dodge engine one they regret in making
my 318 5.2 has 350k on it and will not quit , I know people with 700,000
k on them and still running ????? chrysler regret making this engine
BULLETPROOF
Old 01-23-2013, 11:27 PM
jonnyruckus jonnyruckus is offline
Vehicle: 99 dodge ram 1500 magnum sport
Trim Level: sport
jonnyruckus is on a distinguished road
i did the hughesengine plenum gasket kit and it works great!!! It took me about ten hours(4 broke bolts from whoever did it last) on the website theres detailed step by step instructions that walk you through it!!! to test for plenum gasket failure remove pvc hose from manifold and check vacuum..if its sucking then its blown.
Old 01-23-2013, 11:30 PM
Trim Level: sport
yea you can buy just the gasket but the hughes engine kit comes with everything you need trust me worth every peeny!!!!
Old 01-26-2013, 11:03 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:255
namretsud is a jewel in the roughnamretsud is a jewel in the roughnamretsud is a jewel in the rough
I put the hughes kit on mine and the advantage is you will probably never have to do it again because the original uses a steel plate attached to an aluminum manifold. When heated and cooled the two metals expand and contract at different rate and the object in the middle ( the gasket) gets tugged at eventually giving way. The hughes kit uses a 1/4" aluminum plate and therefore no difference in the interaction of heating and cooling. Hughe's all the way is my reccomandation.
Another check for the gasket gone is take the cover off your throttle body and open the butterflys, if it is dark and oilly looking inside with a flashlight the gasket is leaking.
