Old 01-04-2013, 04:51 PM
blitzkrieg95 blitzkrieg95 is offline
Vehicle: 2011 ram
blitzkrieg95 is on a distinguished road
Default 3" body lift on a 2011
I have a 2011 ram sport , with black pro comp wheels and 33" Toyo open country tires on it , with bilstein upfront set at the second highest setting . My question is, when u guys r putting on body lifts is everyone leaving there hitchs where they are at now or is there a way to move them up with out cutting and welding stuff together. I know I will need to get the exhaust moved up or get pieces that bend up so it ends up closer to the bumper . I'm only looking to get alittle more wheel well gap and plan on sticking with a 33" tire .
Old 01-04-2013, 06:32 PM
CRANKYPISTOL's Avatar
CRANKYPISTOL CRANKYPISTOL is offline
Vehicle: 2011 Ram 1500
Color: Mineral Gray
Rep:13
CRANKYPISTOL is on a distinguished road
WHY????
Body lifts look cheap and don't help with ANYTHING!
I work for Goodyear as a store manager! If you have any tire questions feel free to ask. If I do not know, I will find out.
Old 01-04-2013, 07:41 PM
wilhavens's Avatar
wilhavens wilhavens is offline
Vehicle: 2011 Ram 1500 Sport QCab 4x4
Trim Level: Sport Ram Box
Color: Grey
Rep:34
wilhavens is on a distinguished road
I have the 3" performance accessories lift and I didn't bother lifting the hitch, it looks fine. The pipes are easy, just loosen the joint behind the bumper and bump it up untill the gap closes...
A leader without followers is just a dude walking around...
Old 01-04-2013, 08:12 PM
Vehicle: 2011 ram
Originally Posted by CRANKYPISTOL View Post
WHY????
I do about 99% of my driving on the road and the other 1% I am on trails and fields on my property , so I'm not really needing a lift , but I just wanted a little more wheel well gap . I didn't think the bodylifts looked bad at all on the newer trucks .
Old 01-04-2013, 08:16 PM
Vehicle: 2011 ram
Thanks for answering the question and and give some useful info. Do u happen to have a pic of the rear bumper and hitch ?
Old 01-04-2013, 09:47 PM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2011 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
i dont think the body lifts look bad either i plan on it in the spring myself with the plastic wheeel well cover in the rear it hides the gap alot better but i will get the front gap gaurd to keep crap out of the engine bay also dodge body doesnt expose frame like chev still looks nice and clean in my eye
Old 01-04-2013, 10:55 PM
NaturalBornBiker's Avatar
NaturalBornBiker NaturalBornBiker is offline
Color: Deepwater Blue
NaturalBornBiker is on a distinguished road
Lets see some pics!
Old 01-05-2013, 02:29 AM
WHY????
What makes it looks cheap?
They certainly help with 1) getting your truck higher 2) clear larger wheels 3) cost less than an actual lift kit (for those who don't require a full blown kit) 4)well...there are other benefits but ill leave it with those
The thing with the 4th gens is they hide the body lifts well.
The hitch does not look bad as wilhavens said ^^ but you will certainly need to adjust your tips up
Old 01-05-2013, 02:33 AM
Its. It as bad on the front when used with a leveling kit. It's much more apparent with a lift kit, near maxed Bilsteins and then body lift.....like it was in mine.
But I've seen it on with just a 2.5" spacer and it was not as bad as mine.
Try it first and then grab EM if you are still not satisfied. Either way, they are inexpensive and easy to mount up
Old 01-05-2013, 10:26 AM
wilhavens's Avatar
Color: Grey
Rep:34
I'll shoot some up close around the truck today after I install my Mopar seat covers (AKA: Weimaraner drool barriers)...
I also have the Hell Bent Steel leveling kit on mine and until I read the comments about the gaps it never dawned on me that the bay was exposed...I guess when uncle sam decides to send me my tax returns ill have to do something about that.
I am running the original wheels with 35s but I intend to install factory flares and aftermarket wheels that will space the tires out a little more.
I would highly recommend the AIRLIFT rear support bags, best 80 bucks I ever spent on the truck. I tow an enclosed single axle ATV trailer and it is nose heavy so the ability to level it on demand is great...
