Yet Another Ram Heating Problem .... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-04-2013, 10:24 PM
alexbeitzel's Avatar
alexbeitzel alexbeitzel is offline
Vehicle: 1999 Dodge Ram 1500 5.9L V8
Color: Purple
alexbeitzel is on a distinguished road
Default Yet Another Ram Heating Problem ....
Hey guys
I know there are a million threads already about this problem, but I can't seem to find one with my set of issues. The heat in my truck is barely functioning (brings temperature up to maybe 45 degrees). Water circulation is 100% good, with a new radiator and a new water pump and both the send and return line from the heater core are warm, so I know it's not clogged. This led me believe it was a blend door issue or a relay issue. I took the relay out and manually turned the blend door to be 100% heat and still I get nothing more than barely luke warm. I can't imagine it being a heater core with the warm water entering and leaving. I'm out of ideas and I live in a cold Pennsylvania town lol
Thanks!
Old 01-04-2013, 11:15 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Try the heater resistor
Old 01-05-2013, 12:25 PM
Color: Purple
Thanks for the quick response! What exactly is the function of the blower motor resistor? (sorry, I'm kinda an idiot with this) I'm assuming that controls the fan speed/on and off function
Old 01-05-2013, 12:41 PM
Resident Technician
Rep:1915
Originally Posted by alexbeitzel View Post
Hey guys
Thanks!
Since you say the heater hoses are warm (and not hot) and haven't said whether or not you're certain it isn't a thermostat problem, I would suspect a stuck open stat. If you still have poor heating after you verify a properly functioning stat, I would think the heater core is at least partially clogged. You can try disconnecting the hoses and back flushing it with a water hose, but if the stoppage is bad enough, core replacement is your only option.
Old 01-05-2013, 02:18 PM
Color: Purple
I did replace the thermostat a while ago, but they're cheap enough I'll just buy one and put a new one in. I flushed the heater core a month ago and it's definitely not clogged. I'll put a new thermostat in though. Thanks for the suggestion!
Old 01-11-2013, 04:56 PM
Vehicle: 95
Rep:1776
The resistor senses the temperature etc...
It's located under the dash on the passenger's floorboard area (where their left toe would be).
It's held in with 2 7mm bolts (I think) and has a 5 wire plug that you can see.
It's a common problem and just stops the heat fro working when everything else seems fine. Sorry it took me so long to get back.
Old 01-11-2013, 05:04 PM
Rep:2929
Using a 190 degree thermostat could cure the problem
the Resister may need a couple shots of CRC Letric Clean, or something similar
ram heating heater core
