United Radio
Old 01-05-2013, 05:35 PM
mikeg87 mikeg87 is offline
Vehicle: 1997 ram 1500 x2
Trim Level: slt laramie
Color: both red
mikeg87 is on a distinguished road
Default clogged heater core
well i got the thermostat replaced and i have tires coming in so i can get rid of the truck shaking. heres the problem turn truck on full bore on the heat and blowing luke warm air i dont know if the heat worked before but the a/c is cold as cold can be but heres the thing since neither hose is getting to terribly warm wich hose is the inlet and the outlet i was going to backflush it but thought id ask if anyone has had any success with this? And to find out wich hose is the outlet so i can backfeed this thing
Old 01-05-2013, 06:06 PM
Rep:1824
If neither hose is getting warm, the core isn't likely to be your problem. You need to find out why the heater hoses aren't getting hot. The heater hoses should be as hot as the upper radiator hose at operating temp.
Old 01-05-2013, 06:51 PM
Rep:2615
I may have a suggestion for you
Your radiator is likely as old as the Ram
Drive it over to
Barsco Co
352 High Street, Watertown, NY
(315) 782-5351 ‎
Tell them about your problem & ask their opinion
Then ask them to how much it would cost to fix it
if they say that the radiator is plugged, ask them what it would cost to ROD OUT the radiator, IF you pulled it out & put it back in yourself
While they are fixing it, go across the street to ARTIE's or SOLURI's
Old 01-05-2013, 07:05 PM
Color: both red
Drive it over to
Barsco Co
(315) 782-5351 ‎
yankee scottys shop is in my back yard pretty much but i blew my garden hose through the heater core and got some brown water comeing out now the hose on the left side if your looking at it gets hot and the hose on the right stays cool so im going to shoot some more water through it as for the radiater being as old as the truck as per the paperwork i was givin it has been changed about a year and a half old main problem i have now as i dident want to run it with a bad thermo in it was the ball joint on the track bar is moving about oh 3/8-1/2 an inch so i know what is causeing my wobble and shake now first thing first make sure its safe to drive then worry about being comfy inside. Oh and as for soluris last time i drove by it looked like it was for sale but arties sounds like a good idear
