Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-05-2013, 08:45 PM
bmcashwell bmcashwell is offline
Vehicle: 99 Dodge Ram 1500
Color: Gunmetal
bmcashwell is on a distinguished road
Default Best Chemical to flush core?
I think my heater core is clogged, I"ve already done a clear water flush got nothing back. I've been reading several people have done the same and the core is clogged, with a few open passages. I'm thinking about doing a chemical flush to "eat" to the dirt out, any suggestions. Why? I've noticed I have no heat.... unless I hit 3k rpm so I'm thinking maybe the high pressure created by water pump is helping force more hot water through the core. Any suggestions on any other causes?
Old 01-05-2013, 09:33 PM
Resident Technician
Rep:1915
A chemical flush is worth a shot. If the inlet hose is hot and the outlet isn't, you surely have a clogged core. It's possible you may have a flow issue with the water pump although it's less likely.
Old 01-05-2013, 11:50 PM
Rep:2755
you could pull your radiator & take it to someplace in your town like
http://harrellsauto.com/radiator-shop/
have them ROD it out
they pull off the tanks & run a rod through all the passages, when they are done, it will be close to new
Old 01-05-2013, 11:57 PM
Rep:4156
I agree with that ^^^^ had it done on my last truck after nothing else worked. I'd start with a flush first. Prestone makes an easy to use flush that you can find at any parts store.
Old 01-16-2013, 08:30 PM
Color: Gunmetal
The little electric motor under the vents wasn't attached properly, also bad vacuum check valve off the manifold and 2 cracked lines. $6 fix. Thanks though!
