Old 01-05-2013, 11:14 PM
dwanton's Avatar
dwanton dwanton is offline
Vehicle: 2013 power wagon 2500 loaded
Trim Level: crew cab loaded
Rep:80
dwanton will become famous soon enough
Default Installed Kenwood DNX6180 nav unit
I had this Kenwood in the garage from another vehicle I had and I am so used to looking over and seeing a map of where i am . LOL
I bought the installation kit from ebay . $85 - came with the
PAC C2R_CHY4 , antenna plug and the mounting brackets
http://www.ebay.com/itm/250893302443...84.m1423.l2649
this is their 2010 model i think
my 2010 does not have the outlet on the right side of the radio surround so i only had to remove the 2 - T20 torx from the top .
I sat at the kitchen table for about 30 minutes splicing the the harnesses together , the colors were exact and the direction on what to do was right on. they give you 2 harnesses in the kit -- one for alpine amp set up and one without amp.
after the face plate was off I just let it hang down , I didnt disconnect any of the heater control or the other stuff.
then just plugged in the harness , antenna , microphone , gps antenna and the auxilary input wire for listening to pandora or slacker radio . this Kenwood unit comes with a USB wire that comes out the back that you can plug any phone wire into it.
the radio fit so tight in the hole that i used a file to loosen up the fit and the metal plate in the back i just used the handle of a hammer to bend the bracket open -- still a very snug fit.. but nice
the mounting brackets that go on the sides of the radio had to be altered alittle -- I had to break off the tabs so that the face plate clips would fit through .
came out nice
biggest issue was setting up my bluetooth for my new phone -- i emailed Kenwood today (saturday) at 1130am asking if there was something i was missing , and they emailed me back around 2pm with the answer . I couldnt believe they emailed me back so fast and with the correct answer of what I needed to do to get the new samsung note 2 to connect bluetooth. everything works great now .
i have a couple apline r type 10's , amp , and a 30 farad cap , but nt sure if i want to bother jambing all that stuff in this truck . been there and done that before and its a big pain in the butt !
2013 power wagon 2500 - 5.7 everything but leather.
Old 01-07-2013, 06:11 PM
REALmenRAMit's Avatar
REALmenRAMit REALmenRAMit is offline
Vehicle: 2012 Ram Hemi RCSB 2WD Express
REALmenRAMit is on a distinguished road
Looks good! Is there any quality difference over stock with the bluetooth? Positive or negative?
I want to eventually do a SQ setup with some components. Id love to go with a aftermarket double din but dont want to lose the ability, or quality with the hands free system and being able to play music through bluetooth. I also love the range the stock unit has. Allows me to sit on the tailgate and use my phone to control the music.
******2012 RCSB RAM Express******
Stay tuned.... Modifications will follow.
Old 01-07-2013, 07:09 PM
Rep:2620
Was there anything special that had to be done to insure that the new radio worked with the Rams High Speed Bus System ?
Or is the High Speed Bus System completely bypassed ?
Old 01-07-2013, 08:32 PM
dwanton's Avatar
Rep:80
I just made sure i was buying the correct wire harness that was for my year truck without alpine system -- it just happens that the PAC kit comes with both wireing harnesses anyways .
I am not sure what is inside the PAC little blue box -- but i would guess the has something to do with compatablity .
Old 01-07-2013, 08:53 PM
dwanton's Avatar
Rep:80
If my truck came with factory navigation and bluetooth I would not have changed anything . I only had this Kenwood from another truck that didnt come with nav either .
I dont know what the factory dodge nav bluetooth sounds like so I cant compare for you . sorry
This is my first Dodge truck , but have owned alot of chevy trucks , so comparing the chevy stock nav with bose -- I never switch them out -- bluetooth was great and the plugging my phone in to listen to pandora or slacker didnt bother me and sounded great .
now this Kenwood head unit sounds dam good too -- comparing it to the factory unit that was in there , it is way better . I am suprised how the factory non alpine speaker have such clean sound and really good bass .
the range is pretty good , i have been away from my truck while it was running and my phone answered in the truck while i was tring to answer it , and laughed cause I didnt know why I couldnt talk to the person who called but then saw it was connected to the trucks radio.
I hope this helped some
Old 01-15-2013, 02:29 PM
brianmaloney87 brianmaloney87 is offline
Vehicle: 2012 dodge ram
brianmaloney87 is on a distinguished road
did the stock xm radio antenna plug into the kenwood or is there a seperate module you have to buy to retain your xm.
Old 01-15-2013, 09:04 PM
dwanton's Avatar
Rep:80
it does not fit the kenwood plug -- I tried
i am thinking about looking into it , to see if there is an adaptor . you can get XM for 6 months for $25 .
Old 01-15-2013, 09:29 PM
buddyleewv buddyleewv is offline
Vehicle: 2012 Dodge Ram Quad Cab
Trim Level: Tradesman
Color: True blue
Rep:30
buddyleewv is on a distinguished road
i put in a kenwood 9980hd and my factory sirrius antenna fit into the brain of the sirius unit with no problem i dont know about xm
