Old 01-06-2013, 11:49 AM
ramrunner02 ramrunner02 is offline
Vehicle: 2002 Dodge Ram 1500 4x4
ramrunner02 is on a distinguished road
Default lift advice please
Hey y'all. Im a newbie to the forum with a new to me used 02 1500 SLT 4x4. This isnt my first dodge. But ive never lifted one before and i would like some advice. Its stock set up with 32" nitto terra grapplers, on the street that's fine. But i dont stay on the road often, i plan on being able to take this truck out in the swamps where i do my hunting, and playing in the mud. I would at least like to level it but i woild really like to put about 6" of lift under it. Any way to do this for under $1000? Im gonna do the work myself but i really dont wanna put too much into it seeing as i have an $8000 loan to pay off. Any and all help and advice is much appreciated
Old 01-09-2013, 12:02 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Leveling is free, just crank the torsion bars.
As far as a lift goes, if you're looking for clearance that will come from the tires so you might be able to get away with a cheap body lift to clear larger tires. A suspension lift wont happen for under 1K.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
Old 01-10-2013, 03:21 PM
RAM4life21 RAM4life21 is offline
Vehicle: 2002 dodge ram
Trim Level: new body style
RAM4life21 is on a distinguished road
i'm running into the same problem. i have a 02 ram with 33" generals grabber 1st gen. people have said that when you turn the torsion key to much that it could go through the floor board, if you hit a rut or big hole? please let me know what ya think.
thanks
Old 01-10-2013, 05:14 PM
REALmenRAMit's Avatar
REALmenRAMit REALmenRAMit is offline
Vehicle: 2012 Ram Hemi RCSB 2WD Express
REALmenRAMit is on a distinguished road
thanks
Ive had plenty of friends crank torsion bars till there aint no threads left then turn around and beat the piss out of the truck. Never seen or heard of one blowin out and comin through the floor board.
You can always get aftermarket "leveling" torsion bars so you dont have to crank them to a stiff point.
******2012 RCSB RAM Express******
Stay tuned.... Modifications will follow.
Old 01-11-2013, 03:32 AM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:64
thanks
Ask for proof, post it and I will believe it...Until the, it's a BS story... (it a fairy tale to those who believe it) .....
Stock or aftermarket it will require the same amount of pre-tension ("force") to lift the truck. Aftermarket keys will not magically reduce the force (pre-tension/Load) required to suspend the truck, let alone raise it above stock.. Physics is Physics. ..
Old 01-12-2013, 12:24 PM
alright thanks guys. ill posted s pic after i turn the torsion keys. one more question. which do ya think is the best suspension lift?
Old 10-15-2013, 10:26 PM
i know its been a while since ive been on here but do all body lifts require stretching/ lengthening the metal brake line at the master cylinder?
Old 10-15-2013, 10:34 PM
Hayden0351's Avatar
Hayden0351 Hayden0351 is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: Laramie 4x4 Offroad
Hayden0351 is on a distinguished road
DO NOT put on a body lift if you wanna take it offroad...Just put a 5" RCX lift and 35s on mine pic does it no justice tho
5" Rough Country Suspension Lift
35"x12.50x17 Cooper Discoverer STT
K&N 57-1533 Cold Air Intake
Dawn Matte Black Fender Flares
K2 Black LED Tail lights
K2 Halo Headlights
Old 10-16-2013, 12:21 PM
Hayden0351's Avatar
Make sure you get an alignment after you tignten the torsion bars...also don't crank them all the way it makes the ride pretty stiff..id recommend tightening it all the way then go back about a 1/4 to 1/2 turn
