Old 01-13-2013, 09:51 PM
StuderCo StuderCo is offline
Trim Level: Sport Quad Cab
Rep:24
StuderCo is on a distinguished road
Yeah it's definitely in the radio in the settings, as Zixxer said just above. What I've noticed with that ECO light, doesn't impress me though
1. On the highway, if you're traveling over approx 90 km/h, the ECO light does not turn on. It seems to need all 8 cylinders to keep highway speeds. Anyone else have this problem? I chose the 3.55 rear axle ratio...which, so far, I'm hugely regretting. I don't know if that makes any difference though.
2. The fuel mileage really does not increase when the ECO light comes on, especially cruising around town (50-70 km/h). It just lights up and sits at the same mileage level. I notice no mileage improvement.
Honestly, did I screw myself over with this 3.55 axle ratio? Every day I think more and more that it was the incorrect choice. Any ideas?
2013 Ram 1500 Sport Quad Cab
14" Magnaflow, Full Tint, Stubby Antenna, Cabin Air Filter, PE Jackrabbit
2007 F-350 Lariat 6.0 FX4 Crew Cab - SOLD
Studs, Gaskets, EGR del, 4" Turboback, SCT X3 w/ SPD, PHP Hercules 100, 4.5" lift, S&B Intake, Coolant Filter, Black Bumpers, 35x12.5x20", Smoked Lights, 6000k HID's
Old 01-14-2013, 12:54 AM
slauso slauso is offline
Vehicle: 2016 Dodge Ram 1500 Crew
Color: Maximum Steel Metallic
slauso is on a distinguished road
What do you mean screwing yourself? Do you feel you should have went with the 3:21 or 3:92 ratios?
Old 01-14-2013, 10:35 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
if its anything like a 2012... mine didnt get good on fuel til i hit 10000 km
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 01-14-2013, 03:30 PM
Rep:24
Yes, exactly. I keep feeling like I should have gone with the 3.92 ratio. I do mostly city driving but I picked the 3.55 anyways, for highway fuel ecomony and to keep the rpm low. It really lacks in the city though. Certainly doesn't feel like 400+ tq and 395 hp in the city.
Old 01-14-2013, 09:36 PM
I think the 8spd with the first 2 gears being 4.71 and 3.14 would have made a difference in stop and go city traffic.The 6 spd does not have these ratios. I plan on ordering a 2013 with the 8spd and 3.21 or 3.55 gears. I do mostly highway but I would try and test drive each if possible. I only tow my boat and snowmobiles so I hope the 3.21 would be ok. A little nervous about wether the trans would still be able to maintain o/d with the 3.21 gears pulling my boat(3000lbs). Not sure if any of the ram guys on here have an opinion.
Old 01-15-2013, 12:01 AM
ShaneDiddy ShaneDiddy is offline
Vehicle: 2013 Dodge Ram 1500 Sport
Rep:19
ShaneDiddy is on a distinguished road
I may be wrong but I don't know if the ECO light is an indication that the MDS is working...On my current 2012 Jeep wrangler I have an ECO light also that usually comes on as long as I'm not pressing the pedal to accelerate, it doesn't show any immediate mileage increase on the dash display which really isn't an accurate judge of your overall mileage on short periods. The ECO light on my Jeep is an indication of the optimum condition for milage.
Old 01-15-2013, 12:05 AM
Rep:19
I'm a little torn on this ...I plan on getting the 8-speed and deciding on the 3.55 or 3.92. Ill probably end up going with the 3.92 as from what I've been reading so far it shouldn't be much noticeable difference in gas either way.
Old 01-15-2013, 02:02 PM
Rep:24
So if this is the case, how is it indicated to the driver that MDS is active?
Old 01-15-2013, 03:34 PM
2013Sport's Avatar
2013Sport 2013Sport is offline
Rep:20
2013Sport is on a distinguished road
I have a 2013 with 3.92 and in order for the eco light to turn on I have to be on perfectly flat level ground with zero head wind. I had to drive 95kmh for the light to stay on and if you are going up the slightest grade poof turns off. I find it kinda pointless cause at 95kmh your not going to burn much gas anyways.
I drove an 09 or 10 can't remember but the light would stay on almost all the time as long as you didn't pass 110. Maybe it gets better with time? I'm only at 1400km.
Old 01-15-2013, 10:53 PM
rraulston rraulston is offline
Vehicle: 2013 Ram Sport Crew Cab Hemi
Rep:7
rraulston is an unknown quantity at this point
My 2013 Sport Hemi with 3.92 gears hauls ass......Also tows fine too. 6100 lbs., truck holds 4th gear at 75 mph at 3000 RPM. Seems to be a sweet spot......355 gears would have sunk me......fuel mileage as indicated was 6/7 mpg....Oh well!!
