Old 01-06-2013, 11:00 PM
black57hemi black57hemi is offline
Vehicle: 2009 dodge ram sport crew cab
Trim Level: sport
Rep:13
black57hemi is on a distinguished road
Default headlights not working!!! help!!!
I just installed some spyder projector headlights, all bulbs are new and all wiring is correct. Well now both low beams and high beams are not working but fog lights and turn signals work...I have done a little research and see that it could possibly be the TIPM Which i guess can be very expensive to replace. I wonder if the TIPM can be reset somehow. Not very familiar with it. Any knowledge in this would be greatly appreciated. I work late nights and need my headlights.
Old 01-06-2013, 11:19 PM
Sphinx's Avatar
Sphinx Sphinx is offline
Vehicle: 2012 Ram 1500
Rep:166
Sphinx has a spectacular aura aboutSphinx has a spectacular aura about
Check that wiring again... Have you reset the system by disconnecting the battery for 60 seconds? I had troubles with my last car and it came down to the wiring I installed. I thought it was right, but then took it all apart and come to find out it was wrong.
"SPIKE" - Sport Mirrors - Color Matched Grill Emblem - Black Hood Spears - Metallic Silver Dash Trim - Custom Tailgate decal - Blue LED Interior Accent Lights - XPressKit Remote Start - Euro Antenna - 4' Oval Spyder Side Steps - TonnoPro Cover - Clear Third Brake Light - 8000k HID High/Low & Fogs
Old 01-06-2013, 11:23 PM
Trim Level: sport
Rep:13
I have checked..rechecked..then checked again..crazy thing is that they all worked. I had hids installled. Then one went out so I just re-installed factory halogens...now all four are not working just doesn't make sense
Old 01-12-2013, 11:39 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
[QUOTE=black57hemi;977330]I just installed some spyder projector headlights, all bulbs are new and all wiring is correct. Well now both low beams and high beams are not working but fog lights and turn signals work...I have done a little research and see that it could possibly be the TIPM Which i guess can be very expensive to replace. I wonder if the TIPM can be reset somehow. Not very familiar with it. Any knowledge in this would be greatly appreciated. I work late nights and need my headlights.[/QUOTE
I would go back to a setup that was working and see if it still works. If it does then you need professional help to install the lights.
And if they you can still work nights.
Old 01-12-2013, 11:44 PM
Trim Level: base
Color: blue/silver
I'd check fuses. Check wires to determine if you have power keep going until you find power or fuse, It is work thats why tech get the big bucks.
