tonneaucovered.com
Old 01-07-2013, 11:32 AM
live2ride live2ride is offline
Vehicle: 14 1500 5.7 CC 6.4 8sp
Color: Maximum Steel
live2ride is on a distinguished road
Default tire / lift clearances and fixes?
Good day,
So i got a 4" rancho susp lift and got some ion alloy rims with a -8mm offset and 315-70-17 terra trac tires on order coming in. should of been in by now...
I did a bit of reaserch and read I should be fine but I want to confirm that as im getting a bit worried ill run into some issues.
should I expect any rubbing with a -8mm offset on 17x9" rims with a 315-70 tire?
I know the rancho susp lift kits come with a bigger steering knuckles and I needed a offset so i can have the tire and rim clear the knuckle properly.
I read that - offsets cause bigger tires to rub in the fenders? what are fixes some of you guys have done to cure the issues?
Trying to have an idea of what I can do if I do run into any issues once im at the garage installing my new rims n tires.
Here's an older pic of my truck with the lift kit and oem tires if I remember right
dont mind the dirt... it did need a bath at the time lol
Thanks in advance,
Jesse
2005 dodge ram crew cab 1500 5.7L hemi- cat back Gibson exhaust, Superchip, Intake spacer, BBK CAI, 4" Rancho Susp lift, 17x9 -8mm ion alloy 133 rims with 370-70 terra tracs SOLD
2014 Ram 1500 CC longbox hemi big horn, 3.92 gears 121L tank
Old 01-09-2013, 12:30 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
I didn't see any backspacing requirement to run their lift (aside from stock BS/offset). You should be more than fine with that offset, for a stock set-up you only need a +12mm offset on a 9" rim to clear that tire width.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
