Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 01-07-2013, 12:21 PM
bigblock4speed bigblock4speed is offline
Vehicle: 2004 Dodge Ram 1500
Color: Grey
bigblock4speed is on a distinguished road
Default Truck leans to the left
I have an 04 1500 with the stock suspension. I haven't swapped anything out for aftermarket parts. In fact everything with the exception of the ball joints is from the factory.
I've noticed over the past 6 months the truck is beginning to lean to the left. The driver's side is about 2-3" lower than the pass. side. It's noticeable when viewed from the rear, and when looking at the truck from the pass. side, the gap between the top of the tire and wheel well is dramatic.
I did try and crank on the torsion bar on the drivers side to correct it, but it made no difference.
There do not appear to be any driveability issues related to this.
Any ideas?
2004 Ram 4.7 5spd
250K miles
Old 01-07-2013, 12:23 PM
Rep:1885
You may also have a left rear leaf spring that's weak. How many turns did you put on the torsion bar?
Old 01-07-2013, 12:53 PM
Color: Grey
I put a turn and a half on the drivers side torsion bar.
Would the weak leaf spring also create a clunk if I were going over a speed bump or uneven pavement slowly one tire at a time? Because occasionally there is a noticeable clunk-clunk when encounter a slow speed bump.
2004 Ram 4.7 5spd
250K miles
Old 01-07-2013, 08:07 PM
roby1217's Avatar
roby1217 roby1217 is offline
Vehicle: 2014 Ram 1500 CC 5.7L
roby1217 is on a distinguished road
If you find the answer to the clunk let me know. i also am experiencing a clunk over speed bumps. I am changing Upper control arms and lower ball joints tomorrow. Shocks are brand new also. Not very much left if it doesnt stop after tomorrow. I will update tomorrow afternoon if all goes well
Old 01-07-2013, 10:23 PM
Rep:1885
You may need to put a few more turns on the bar to get the adjustment you need. If it seems excessive, you may have a damaged component somewhere.
Old 01-08-2013, 08:29 PM
roby1217's Avatar
I found the source of my clunk. It was sway bar link on passenger side. looked fine, but the ball was popping in and out of the joint. New Upper Control arms, new lower ball joints, new sway bar links, and new shocks and new tires. Rides like a new truck!
Old 01-10-2013, 07:59 PM
namccanna's Avatar
namccanna namccanna is offline
Vehicle: 2013 Dodge Ram 1500 SLT
Trim Level: SLT Big Horn Edition
Color: Black & Chrome
Rep:50
namccanna will become famous soon enough
I would agree with the leaf spring diagnosis....may not be the leaf itself but something in that area....a shackle or something. I had a Mazda B4000 the shackle rotted off of. The driver's side rear sagged more than the front...the leaf was riding on the box...still worked (kinda) but just was up on the box.
I WELD FOR MONEY! IF YOU WANT LOYALTY.....BUY A DOG!
Old 01-15-2013, 12:06 PM
Color: Grey
Thanks for the suggestions. Haven't had a chance to get under there and check it out, but when I do, I'll report back.
2004 Ram 4.7 5spd
250K miles
