Old 01-02-2013, 02:36 PM
DodgeRam1996 DodgeRam1996 is offline
Vehicle: 1996 Dodge Ram 1500
DodgeRam1996 is on a distinguished road
Default dies while driving
My 1996 Dodge Ram started to stall while driving, no warning, engine just dies, usually on flat surfaces, and while cruising along at 45-55 MPH. It starts right back up usually. When it dies I usally coast off to the side and stop when I start her right back up. And when I hooked up an OBD II reader there are no error codes.
So far I only replaced the IAC and cleaned the throttle body, I checked the MAP Sensor, and the TPS sensor, they seem to be working like they are designed to do. I also checked the ASD and Fuel Pump Relay and they are at the specified meter readings. Listened to the fuel pump and that seemed to charge in tthe 3-5 second specifications.
Any help would be greatly appreciated!!
Old 01-02-2013, 03:35 PM
Rep:1909
I'm thinking more along the lines of a CKP sensor losing signal.
Old 01-02-2013, 05:12 PM
wouldn't the CKP Sensor throw an error code?
Old 01-15-2013, 03:41 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
my truck did the same thing as yours is doing, the last thing i tried was the crank sensor with no error codes thrown and that was the problem
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 01-15-2013, 04:37 PM
Rep:1909
No, not always. The 4.0 liter Jeep engines are notorious for going bad (shorting internally), shutting down the PCM and never throwing the first code.
