Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 01-10-2013, 02:08 AM
dbezzek524 dbezzek524 is offline
Vehicle: 2013 Dodge Ram 1500 Express
dbezzek524 is on a distinguished road
I will try and get it hooked up to a scanner but i had the trans serviced not to long ago with a full flush and everything so idk why it would be that and it only knocks when the idle drops below 500 rpm before it drops there is no knocking of any sort, do you still think its the trans plate?
Old 01-10-2013, 11:30 AM
LEW LEW is offline
Vehicle: 2002 Ram 1500 Quadcab 4X4
LEW is on a distinguished road
Originally Posted by dbezzek524 View Post
I am noticing a loss in power, with a drop in mpg, with a knocking or kind of sounds like its misfiring under the truck. I can also feel the tapping in my seat and it only occurs when the truck sits in park and the trucks idle drops to 500 rpm when it is usually around 610. Also at time when I first run the truck it has problems shifting from 4th to 5th. Please help thanks.
I have a similar problem shifting to high when the transmission is cold. After mine warms up it will then go ahead and shift.
Old 01-10-2013, 08:09 PM
Thats how mine is but i cant figure out what the problem is because i had a big drop in gas mileage.
Old 01-10-2013, 08:33 PM
LEW LEW is offline
I haven't notice a significant drop in mpg associated with the slow shifting. Mine will finally shift after 3 or 4 miles even in cold weather. If yours takes long enough to shift, it will lower your mpgs. My "late" shifting started before transmission service (fluid and filter etc) and is still doing it after.
