Old 01-08-2013, 09:59 PM
NHFD170 NHFD170 is offline
Vehicle: 2011 Dodge ram 1500
Trim Level: slt big horn
Color: Rugged brown
NHFD170 is on a distinguished road
Default Lift vibration
I installed a rough country 2.5F/1.75R lift in my truck. Now has a vibration in front drive line when in 4wheel drive. Any thoughts ?
Old 01-10-2013, 08:32 AM
Bruce E's Avatar
Bruce E Bruce E is offline
Vehicle: 2013 Ram Longhorn Crew Cab
Trim Level: Longhorn
Rep:55
Bruce E will become famous soon enough
It is caused by the increased angle on the CV joint. To the best of my knowledge the only cure is to remove the lift or instal Kore high angle CV joints ($800). I have the same issue with my truck but its only at low speed and not so bad as long as I don't accelerate to quickly.
Vararam Cai, ARE Cap, 35" Dick Cepek Mud Country, DC-2 Wheels, Diablo Trinity.
Old 01-10-2013, 10:01 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
That's why some go to a "lift kit", they usually come with a drop bracket for the front differential which puts the cv joint back to stock location or eliminates the angle that levelling kits cause.
Old 01-10-2013, 10:04 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
From my understanding, Some trucks exhibit the vibration in stock form (pre level) and it gets more noticeable after leveling. Some trucks don't have the vibration in either form. I just installed the same rough country kit and I have no noticeable vibration, before or after.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 01-13-2013, 02:26 AM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
All correct.
I had the same issue on my 2007 when I had a 2.5" level...I swapped it out for a 2" and it's significantly improved. So that MIGHT be an easy fix for you...
I will be getting a 2013 Sport 4x4 this summer and plan to go with the Bilstein 5100 adjustable shocks as these seem to change front drive angles much less...and I would only run them at 2.1" anyway as opposed to the max of 2.8" lift...
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
Old 01-14-2013, 05:44 PM
Color: Rugged brown
thanks for the input guys. Was confirming what i was thinking
Old 01-21-2013, 12:00 AM
latitud's Avatar
Rep:71
update: got to do some extensive driving in the recent snow fall..I have a vibration in 4 HI when accelerating quickly, but not under normal acceleration or cruising at any speed. I can live with it.
Old 01-27-2013, 08:06 PM
fx2offroad's Avatar
fx2offroad fx2offroad is offline
Color: BRIGHT SILVER
Rep:17
fx2offroad is on a distinguished road
I've never had any vibrations in mine with the Rough Country or the Rancho Quicklift Loaded setup I have now.
Thought I might add that if your wheels are packed with snow it will cause vibrations in the front end. I found that one out....
