Old 01-08-2013, 09:03 PM
jrod922 jrod922 is offline
Vehicle: 2012 Ram 1500
jrod922 is on a distinguished road
Default DBall Xpresskit- no T-harness
Has anyone hooked up thier DBall remote start without using the T harness, and are pic's available? I tried searching for a drawing or how-to on the forum, and You tube etc... all I can find is hooking up with the t harness. From the looks of the PDF on Xpresskits web site, looks like I just have to splice into the Can Hi and Can lo, then cut the ignition wire, run it into the dball, and back out to the ignition switch?
Old 01-08-2013, 09:36 PM
EXPRESSIVE EXPRESSIVE is offline
Rep:49
EXPRESSIVE is on a distinguished road
Keep it simple brother and do yourself a favor and order the T harness. I installed mine lastnite in literally 3 minutes (5 counting zip tieing it up). Totally worth the $26!
Another reason to use the "T" is if anything goes wrong you can switch back to factory setting and avoid a possible towing charge.
Old 01-08-2013, 09:38 PM
redlightmike redlightmike is offline
Vehicle: 2012 Ram Express RCSB
Rep:36
redlightmike is on a distinguished road
can someone help me out with part numbers or links to get these parts, ive been wanting to add remote start on mine.. thanks
2012 Express RCSB..2/4 belltech drop, 22s,tonneau cover, 4.10s, true duals with x and magnaflows,vararam air grabber,180 tstat, 2800 circle d, diablosport trinity....headers and ported tb(coming soon)
Old 01-08-2013, 10:46 PM
The link for ebay, where I and other forum members got thier Dball from:
http://www.ebay.com/itm/290722973432...84.m1423.l2649
The seller will flash it for you, I didnt realize the harness was seperate.
The part number for the T-Harness is: CHTHD1
Found on amazon, or a few other sites.
Old 01-08-2013, 10:50 PM
I did order the harness today, just wanted to have the remote start active for my trip to WV this weekend. I can wait I guess... just have some free time over the next few days and wanteed to tinker with it.
Old 01-09-2013, 12:47 PM
jgos929 jgos929 is offline
Vehicle: 2012 Dodge Ram
Trim Level: SLT Lone Star
Color: Sagebrush
Rep:-5
jgos929 has a little shameless behaviour in the past
I just ordered my Dball and T Harness. Can someone tell me if this allows you to leave the truck running, remove the key and then lock the doors?
Old 01-09-2013, 01:48 PM
Asur Asur is offline
Vehicle: .
Rep:4373
This is a remote start, it works by hitting the lock button on your FOB 3 times, so basically your Truck got locked 3 times and the engine is running. If your Engine is running with the FOB in the ignition, and you turn off the truck, it will turn it off, you can then if you want hit the Lock button on the FOB 3 times and it will restart the Truck. To my knowledge, it will only run the truck for about max 15min.
oh by the way, if you remote start your truck and hit the Lock button on the FOB again 3 x, it will shut the truck down.
Old 01-09-2013, 08:09 PM
Well, looks like I am going to keep it simple, do myself a favor and wait for my T harness to come in being thats the only advise I got so far. Should be here hopefully by friday before I leave for WV. I will post my success or failures
Thanks
Old 01-09-2013, 10:21 PM
Vehicle: .
Rep:4373
Thanks
Should be a success, took me all but like 5 min to install and setup.
Old 01-09-2013, 10:42 PM
Mojack's Avatar
Mojack Mojack is offline
Vehicle: 2012 Ram 1500 ST
Color: Deep Cherry Red
Rep:65
Mojack will become famous soon enough
I really need to get busy and order mine, I get reminded every morning.
2012 Ram 1500, 1986 RamCharger,
1972 Duster 340, 1965 Valiant 340
