Old 01-09-2013, 02:18 PM
BurntCherryCoke BurntCherryCoke is offline
Vehicle: 2012 Dodge Ram 1500 Lonestar
Trim Level: Lonestar
BurntCherryCoke is on a distinguished road
Originally Posted by RamTech View Post
I agree with much of this. Even with the A/C on while moving at highway speeds, it's unlikely the electric fan will come on. Messing with the cat is a bad idea, IMO. One - because I've never seen any imperical evidence that there's any mileage to be gained and two - it will kill your warranty.
Would it just be smarter to replace the headers and the rest of the exhaust?
If i did mess with a Cat, i'd probably go with a dealer approved high-flow cat.
Old 01-09-2013, 02:25 PM
blocking grill will heat up the motor quickly, I've done it while testing for the track and forgot to take them off when I was testing other things...
Here's another noob question for you... what if you added portholes or fender vents? would that decrease the motor heat by blocking the grill?
Old 01-09-2013, 09:23 PM
mikennrg mikennrg is offline
Vehicle: 2012 RCSB Express
Rep:97
mikennrg will become famous soon enough
Again the goal of the grill block is to REDUCE airflow into the engine bay. Adding vents sets you right back to square one if not worse. Unless you have active grill shutter you'd only want to block some of the grill not all of it. Maybe play around with corrugated black plastic. Start with 25% of the grill blocked and see how cooling is then add or subtract since corrugated plastic is cheap.
Also the blocking can be inside the grill between the grill and radiators. The new vehicles with grill blocking tech all have them hidden behind the grill and radiators.
Old 01-10-2013, 01:33 AM
Oh no i understand what you were saying about reducing airflow and canceling out what i'm trying to do... i just didn't think fender vents would do that since they are facing the direction the air is already pushing and it would be a place for the air to escape. just my thoughts.
I like your idea of blocking the grill a little bit at a time.
Old 01-10-2013, 01:57 AM
Rep:97
I wonder if the 2013 active grill shutters would retrofit on our Rams. This would eliminate any heat concerns.
Old 01-10-2013, 11:09 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
my track mod...
Old 01-10-2013, 03:32 PM
Yea i'm tempted start making some phone calls to dodge to see if that's possible.
my track mod...
nice!
Old 01-10-2013, 09:04 PM
chefred112's Avatar
Rep:656
there has to be some direct airflow thru the radiator (most of the time). One thing I thought of trying if i were to close the grill (track mod), is to run ducting from my foglight holes to the front of the radiator. then you don't have the parachute effect like when the grill is open...
Old 01-12-2013, 10:15 PM
That is genius!! What I'd like to see if there is a way to simulate that in a wind simulator program to see if it would work.... Or... Make my own wind simulator with colored water and take a model dodge ram... Tweet it and see if it works.
