Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 01-09-2013, 10:45 AM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Default 2010 4.7L Spark Plug change
Anyone have any links or advise to help me out with this change?
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 01-09-2013, 10:49 AM
Rep:1845
You may need a thinner walled plug socket than you find in most took kits. Literally, the difference in one fitting in the plug tubes can be as little as .030". I got mine from Snap-on band the outside diameter is .830". A socket with an outside diameter of .865" will not work.
Old 01-09-2013, 11:08 AM
Color: Gloss Black
Rep:141
Alright good to know! That'll help, thanks man. Ill measure my socket when I'm home with calipers.
