Biggest Tires WITHOUT MODIFICATION? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 01-09-2013, 02:46 PM
Seacoast-NH Seacoast-NH is offline
Vehicle: 2005 RAM 1500 Orng Cnty Chpprs
Seacoast-NH is on a distinguished road
Default Biggest Tires WITHOUT MODIFICATION?
2006 RAM 1500 SLT.
What are the BIGGEST tires I can put on without modifying a 2006 RAM Quad Cab 5.7L 4WD?
It's an Orange County Choppers Edition.
Old 01-09-2013, 02:59 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
uhmmmm. why is there a link to a laptop? haha
Old 01-09-2013, 03:27 PM
Because that new "ask a dodge tech" thing posts their ad text instead of your photo text - no matter how many times you cut and paste. At least I know I can change it here now thankfully!
https://plus.google.com/u/0/photos/1...96002015890482
Old 01-09-2013, 03:35 PM
Rep:1900
Ohh okay. Well good lookin truck. Hopefully someone will answer you shortly. I would suggest usin the search function in the mean time, I'm sure this question has been asked before. I know it's the WIDTH that restricts us on these 06-06, not so much the height. I'm betting a 34" would be ideal but that's just me guessin.
Old 01-09-2013, 09:47 PM
ShawnC13's Avatar
ShawnC13 ShawnC13 is offline
Rep:2055
ShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond repute
The ask a dodge Tech section if for site supporting members only that could be an issue as to why it wouldn't go there
Old 01-09-2013, 10:29 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Your info says you own a 2005....is that a mistake because there is quite a difference between what will fit on a 2005 and a 2006. With zero mods on a 2006 from what I have read a 285/65/20 is the biggest you will fit. Anything wider than 285 on the stock rims will likely rub. Unless you want to run 1/4" spacers which would open up a whole new range of sizes.
*EDIT: I just looked at the photo....are those 20's?? And they are aftermarket, correct? Aftermarket rims with different offset than stock could have an affect on how big of a tire you can run. Also, unless I'm missing something then I am going to guess that is a 2005 as it has the 2002-2005 front end. The 2002-2005 4wd trucks have torsion bar suspensions rather than coilovers and can run wider tires. You can easily run a 295 series tire such as a 295/60/20 or 295/65/20. Depending on the offset of those rims I would say you could potentially run even wider, like a 35x12.50.
I know you said unmodified but just so you know....you can also adjust the torsion bars to raise the front and get rid of that stock front rake. It's easy and free with the only exception being you need an alignment afterward.
biggest tires
