Old 11-15-2012, 10:09 AM
cabindoor00 cabindoor00 is offline
Vehicle: 2011 Ram 1500 Crew Laramie
Color: Pearl Brown
cabindoor00 is on a distinguished road
Default TPMS Problem
The two right side tires indicated low at 29 PSI each and they were blinking. I stopped at a gas station and aired them back up to 33 PSI and I drove off. The dash light is still on and the two right side tires are still blinking at 33 PSI. Anyone have any fixes for this? I have a 2011 Ram 1500 4x4 Crew Cab Laramie Edition. The temp outside was around 40 degrees if that helps as well. Thanks for the help!
Old 11-15-2012, 10:14 AM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
Mine does that sometimes, it seems to come on under 30 PSI. I have 1 with a slow leak evidently, so when it happens occasionally it wont go off for a bit. I have to just drive it around and it eventually goes out. If it does not go off then I recommend a stop at the dealership service dept. they will diag. it for ya. Good luck friend.
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 11-15-2012, 10:30 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Yes cabindoor; with the outside temps dropping fast, expect your tire pressures to show their true cold tire pressures. It is an extremely good habit of checking your tire pressures first thing in the morning when you haven't driven on them yet because the simple fact is warm air expands in tires. I constantly keep mine close to 36psi cold and have seen it jump up to 41psi in 90+ degree temps.
Old 11-16-2012, 01:26 AM
Actionjackson's Avatar
Actionjackson Actionjackson is offline
Vehicle: 2013
Trim Level: EXPRESS
Color: WHITE
Actionjackson is on a distinguished road
Would u happen to have hid lights installed.
Old 11-16-2012, 11:31 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
You have to inflate the tires 41lbs cold. And drive for a mile or two.
You can also see this thread. http://www.ramforumz.com/showthread.php?t=91971
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 11-25-2012, 10:27 PM
CRANKYPISTOL's Avatar
CRANKYPISTOL CRANKYPISTOL is offline
Color: Mineral Gray
Rep:13
CRANKYPISTOL is on a distinguished road
Best thing is to AIR THEM UP! 40psi in the winter is the lowest you should run. I run 45psi all year and have had great wear.
I work for Goodyear as a store manager! If you have any tire questions feel free to ask. If I do not know, I will find out.
Old 11-26-2012, 11:29 AM
drew7811's Avatar
drew7811 drew7811 is offline
Vehicle: 2011 Dodge Ram Laramie Crew
drew7811 is on a distinguished road
Has anyone noticed the accuracy between the dash tpms reading and what you actually get with a manual gauge? I have checked mine multiple times (cold and even warm for comparison) and found the computer is always 2-3lbs more than what I am getting on the manual tire gauge. I even used a seperate gauge and it shows the same. Has anyone else noticed this on theirs?
Old 11-26-2012, 11:52 AM
Rep:2616
just air up your tires to what the door sticker reads
drive it for a while & the computer will catch up
the light comes on when your tire(s) are 7 pounds or more low
Old 11-27-2012, 09:00 PM
doug713's Avatar
doug713 doug713 is offline
Rep:33
doug713 is on a distinguished road
I recently had new tires installed and decided to have them filled with Nitrogen instead of air and they seem to pretty much stay consistant at 36 psi but will drop to 33 with extreme cold. Yes I live in Alabama, but I travel all over, even up north..lol. just my 2 cents. They claim the Nitrogen helps the tires last longer,,, hmmm we shall see.. I think it usually costs about $7 per tire to do this, but my tire store didn't charge me.
Old 01-10-2013, 09:25 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
What does it say is the correct pressure on your door sticker? Mine is 40, my TPMS comes on somewhere around 35.
