Freez-n-winter - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10
Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 01-09-2013, 03:22 PM
DOZER 1 DOZER 1 is offline
Vehicle: 1998 Dodge Ram V-10
Color: BACK IN BLACK
DOZER 1 is on a distinguished road
Default Freez-n-winter
Hi, I have a 1998 Dodge 2500 Ram 4X4 pickup with a V10 , No Heat !! , I have the Radiator front blocked, Restricted the water pump hose from 1 1/4"
down to 1/2" , Installed a 1 1/2" Brass Valve on the upper radiator , and tuned into where its about 95% closed, The truck doesn't overheat, all I can get is 160-170 Degrees after idling for a half hour.Then if you drive it , it cools down more. Shot the lower radiator hose , and radiator and it reads 50 -65 Degrees . The fan is working correctly , and yes I have put Three different Thermostats in. Have bleed all the air out, and even had it back flushed . Any Ideas ????? Thanx's Dozer
Old 01-11-2013, 05:41 PM
BigClay BigClay is offline
Vehicle: 1996 2500 V10
Rep:19
BigClay is on a distinguished road
I am running a 185 t-stat, and mine runs about 170-180. I am no other help than that.
1996 extended cab, long bed, with a freshly rebuilt V10
Old 01-16-2013, 11:38 PM
99 V10 99 V10 is offline
Vehicle: 1996 SLT
99 V10 is on a distinguished road
I have never checked mine. But it never fails when you want them to run warm they don't. It seems that the V-10s run cold. My heater works but my temp gauge never gets above 1/4 off cold unless I'm pulling hard.
