Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 01-10-2013, 03:26 PM
SStilwell's Avatar
SStilwell SStilwell is offline
Vehicle: 2009 Ram 1500
SStilwell is on a distinguished road
Default Remote Start / Brake Controller Problems
Well, here's my first real post. And like the other boards I'm on for my K5 and previously my Harley, it begins with a problem!
Remote start first... Finally replaced my spark plugs last night after 170000km. Little bit of a pain in the a$$ having to pull the brake cylinder and boost off, but not really too bad. Anyway, everything's running great, but for whatever reason my remote start isn't going now. When I hit the button I get the single flash like the tank's low, door's open, or whatever other problems disable the remote start. However, full tank, doors and hood are closed, etc. The only thing I'm thinking now that I'm typing this is that my hood sensor might be askew. Plugs mean I was leaning over the quarter and climbing all over the damn thing, so that might be out. Anything else I might be missing?
The other is the brake controller. I've had to have this module replaced before after getting lights for ESP off (graphic in bottom right), and alternating ESP/BAS (still no idea what BAS means) and Service 4x4 messages on the EVIC. What happened before was I would get these errors pop up from time to time randomly and they'd eventually clear. When it went on and stayed on I took it in to the dealer and they changed the controller out which of course isn't part of the drivetrain warranty. $400 later seemed to fix the problem. Last night after the plug change it started up again, and of course during a pretty good snow storm that's still going today. Goes on, then it's off when I start the truck again, but will pop up again seemingly randomly while driving. I'm HOPING this controller's not gone again, and no idea why I would have gone through two of these over the last 5 years. NOTHING else on the truck has had any problem, I'll be pissed if I've got yet another dud.
Any input would be greatly appreciated, thanks!
Old 01-10-2013, 03:51 PM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
My remote start does this once in a while as well, I don't know why. My driveway is on a incline, so I suspect the tank level is more sensitive than when on level ground. I check my doors and it looks good. Still, once in a while it will flash and not start.
Old 01-11-2013, 01:00 AM
SStilwell's Avatar
Well checked the hood plunger and that's not it. I did notice one thing though, with the hood open when I hit the remote start I get the expected single flash and horn. When I depress the plunger I can hear something cycle that doesn't with the plunger out, THEN I get the single flash and horn.
Again with doors closed, tank full, on level ground. I tried looking through the window as I hit the remote start, but no message. It just flashes the Dodge symbol then goes blank again.
Any thoughts?
Old 01-11-2013, 06:34 PM
SStilwell's Avatar
Update: I can turn my cruise control on, and by that I mean the icon comes up on the dash, but it will not set and maintain speed...
Old 01-12-2013, 07:54 PM
SStilwell's Avatar
Ok how about this, does anyone have an exploded view diagram of the brake booster assembly?
