Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 11-22-2012, 10:16 AM
jmr's Avatar
jmr jmr is offline
Vehicle: 2014 RAM 1500 Express RC 2WD
Trim Level: Express Regular Cab
Rep:74
jmr will become famous soon enough
Default Question about adding the Compass/Homelink module???
My '12 Express has the Trailer Brake option so it already has the EVIC option
so it displays the temperature only without the compass. I added the overhead console with the Compass/Temp/Homelink module.
All the lights on the console and the Homelink buttons light up too. When pressing the Homelink it displays "Transmitting Channel" in the EVIC but the Compass doesn't display. This tells me the EVIC has a good connection to the new module.
Do I need to have the dealer add sales code JFJ (Temperature and Compass Gauge) to my truck's configuration in order to enable the compass to display ?
'14 RAM 1500 Express RC 2WD 3.6L 8SPD 3.55 W/LSD uConnect 5.0 Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Upper Glove Box, Hemi Dual Exhaust, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner, Lund Genesis Tri-Fold Cover, 22MM OEM Rear Swaybar, Mopar ParkView Camera
Old 11-24-2012, 09:58 AM
jmr's Avatar
jmr jmr is offline
Rep:74
Nobody has done this???
Next Wednesday I'm going to have the dealer add the JFJ sales code and see what happens. With any luck the compass will display.
Old 11-24-2012, 04:51 PM
WHITERAM80 WHITERAM80 is offline
Vehicle: 2011 Dodge Ram
WHITERAM80 is on a distinguished road
Look at this post.
Adding an Overhead Console to an ST - Page 2 - Dodge Ram Forum - Ram Forums and Owners Club! - Dodge Truck Forum
But since you have the trailer evic option no rewiring should be required. Possibly adding the sales code will work if your VIN allows it.
Old 11-24-2012, 08:16 PM
jmr's Avatar
jmr jmr is offline
Rep:74
That should be interesting if the code is available. My truck does have the premium tire pressure monitoring system since it has the EVIC cluster so maybe the sales code JFJ for the Temperature and Compass Gauge will be available. If not I'll need to find a programmer around the St. Louis area.
Old 01-06-2013, 11:32 PM
RAMinCUSE RAMinCUSE is offline
Vehicle: 2012 RAM 1500
Color: Deep Cherry Red
RAMinCUSE is on a distinguished road
I have been reading through several different forums and cant seem to get an answer. What part number did you use for overhead console? Did you already have console and just swap it out? We're the wires plug and play or did you have to splice wires? Do you have any pictures.
Old 01-07-2013, 08:05 PM
jmr's Avatar
jmr jmr is offline
Rep:74
Your going to need the following parts:
Console retainer: 55365119AC
Overhead Console: 1PQ03BD1AA without cutout for Homelink (base).
3 pin connector pinout: 68064999AA
**Remember, these parts are for the basic no frills console. If you want to add options you will need different consoles.
Overhead Console with Garage Door Opener ONLY: 1PQ06BD1AA
Old 01-16-2013, 05:28 PM
jtheruler79 jtheruler79 is offline
Vehicle: 2012
jtheruler79 is on a distinguished road
jmr,
I'm about to order the overhead console and try tackling this. What is the 3-way connector? What is the easiest way to wire the map lights?
Old 01-16-2013, 09:38 PM
jmr's Avatar
jmr jmr is offline
Rep:74
I've attached the wiring diagram that I used to make my harness for the console. It will tell you which cavities in the connectors need to be used.
