Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 01-11-2013, 05:09 PM
eddysald eddysald is offline
Vehicle: 2003 RAM 4.7
Trim Level: SLT LONE STAR
Color: SILVER
eddysald is on a distinguished road
Default transmission problems... i think...
i recently heard a loud knocking sound from what i think is the transmission... let me try to explain what happened. on a cold morning i went to startup my truck to run some errands but i did not let it get up to temp. once i put it into reverse to pull out of the driveway the truck struggled to back-up (i had to give it gas) then when i put it into drive the truck started to shake and stalled about 10ft. from my driveway. i decided to go back and use another vehicle instead, but when i went up the driveway my truck made this loud cranky knocking noise but did not stall. all i did from there is park it and not move it till recently(waited for the days to get warm again) and the same thing happened.
could anyone help me with this given info.?
thanks in advance
Old 01-11-2013, 05:25 PM
Rep:2705
Were there any warning noises before that day ?
It actually sounds like the driveshaft universal joint went bad
it may have nothing to do with your problem, but i ALWAYS set my Emergency Brake, before putting my vehicles in Park & on any kind of a grade
Old 01-11-2013, 05:29 PM
Color: SILVER
not really. i know my truck pretty good(feeling something wrong with it) like i said , the only thing i noticed is that i had to give it gas trying to reverse out of my driveway
Old 01-12-2013, 12:08 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
any warning lights? if so get the codes.
Sean
Old 01-13-2013, 12:28 AM
Color: SILVER
no warning lights... but now it seems to be popping in and out of gear when ever it feels like it.
Old 01-14-2013, 10:36 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:414
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
By "popping in and out of gear," do you mean like going to Neutral and then engaging again? What does your PRNDL display show when this happens?
Old 01-14-2013, 10:44 AM
Color: SILVER
Yes thats exactly what i mean. It goes into nuetral then engages into whatever gear im set at..... And my prndl shows nothing... There is no check engine light or anything
Old 01-14-2013, 11:21 AM
Vehicle: N/A
Rep:414
When you say "PRNDL shows nothing," do you mean it goes completely blank, or do you mean it shows PRND21 but doesn't indicate which one you're in, or do you mean it continues to show the highlight around "D" (i.e. no change from normal)?
Old 01-16-2013, 10:39 AM
Color: SILVER
i meant it doesnt change from normal... it highlights D like if it is working normal...and again no warning lights or anything out of the ordinary showing on the dashboard
Old 01-16-2013, 10:52 AM
Vehicle: N/A
Rep:414
OK, so does the neutralling out seem to be random, or is it only in certain gears, or only when you step into the throttle (more torque)?
When it engages again, does it thump in solidly / firmly, or does it always feel like it's just on the verge of slipping? And once it engages (after slipping), does it stay in one gear until you come to a stop, and after that starts off in 1st gear and then shifts directly to 3rd and stays there?
